Arducam IMX708 camera never worked on Raspberry Pi 4 with I2C dw9817-vcm errors
Hi all, I’m trying to get an Arducam IMX708 camera working on a Raspberry Pi 4, but it’s never worked since I got it. I’ve already reinstalled the OS three times following the instruction sheet that came with it, and it still won’t detect the camera.
During boot I see these i2c errors in dmesg:
[ 7.311146] i2c i2c-22: Added multiplexed i2c bus 0
[ 7.320518] i2c i2c-10: Failed to register i2c client dw9817-vcm at 0x0c (-16)
[ 7.320556] i2c i2c-10: of_i2c: Failure registering /soc/i2c0mux/i2c@1/dw9817@c
[ 7.320604] i2c i2c-10: Failed to create I2C device for /soc/i2c0mux/i2c@1/dw9817@c
[ 7.340733] i2c i2c-22: Added multiplexed i2c bus 10
Any idea what’s going on?
Thanks for the logs. The dw9817-vcm failure at 0x0c usually points to a device tree overlay or config issue for the IMX708 rather than a dead camera, so let’s check your setup.
Can you run the camera bug report tool and attach the output?
  1. Reboot your Pi.
  2. Download the tool:
  3. Make it executable:
  4. Run it:
  5. It will create arducam-bug-report.txt in the current directory. Please attach that file here.
Done. Rebooted, ran the tool, and I’ve attached arducam-bug-report.txt. Environment is a Pi 4 with the Arducam IMX708, set up using the steps on the included sheet. Same errors as before, camera still not detected.
Thanks, got the report. I need to confirm the exact SKU since there are a couple of IMX708 variants that use different overlays. Can you post a clear photo of the camera package, ideally showing the SKU/model marking? That’ll let me verify which overlay should be loaded.
Thanks for taking a look! Here’s a photo of the package - I’ve included both sides in case the SKU is on the back.
Okay, from the package this is the standard IMX708 module. I found the problem in the report: your /boot/config.txt contains:
dtoverlay=imx708-b0311
That overlay is for a different IMX708 variant, and it’s why the dw9817-vcm node keeps failing to register at 0x0c. For this module it should just be:
dtoverlay=imx708
To fix it:
  1. sudo nano /boot/config.txt
  2. Change dtoverlay=imx708-b0311 to dtoverlay=imx708.
  3. Reboot and test the camera again.
That fixed it! The camera is detected and preview works now. Thanks a lot.
One thing though - I noticed something in one of Arducam’s scripts keeps adding dtoverlay=imx708-b0311 back into /boot/config.txt. I’ll keep an eye on it.
Great to hear it’s working. To sum up: those dw9817-vcm i2c registration errors were caused by the wrong overlay (imx708-b0311) being present in /boot/config.txt. Switching it to dtoverlay=imx708 and rebooting resolved it. If one of the Arducam scripts is re-adding the b0311 line, that’s worth reporting separately, but the working config is dtoverlay=imx708.
