Arducam IMX585 B0498 poor low-light performance, PotPlayer camera settings grayed out
Hi all, I just picked up an Arducam IMX585 (B0498) camera module from Amazon and I’m planning to use it as a night vision camera, but the low-light performance out of the box is pretty underwhelming. I’ve been using PotPlayer like the docs recommend to tweak settings, but most of the options are grayed out so I can’t change them. The one thing I managed to change was Backlight Compensation - I dropped it from the default 1 to 0 and that helped quite a bit, but the image still isn’t where I need it. What other settings should I be looking at, and how do I actually unlock them?
Just bumping this since I haven’t gotten a reply yet. Is there specific software I should download to get access to all the camera settings? So far PotPlayer only let me change Backlight Compensation from 1 to 0 on the Arducam IMX585 B0498, which improved things but didn’t really solve the poor low-light performance.
Hi, apologies for the delay. We’ve put together a firmware image to address the low-light behavior on the B0498. One thing to set expectations on: this firmware only increases the scale in manual exposure - it isn’t a full low-light tuning pass. I’ve sent the flash.img file and the flashing instructions to you through private message. Please flash it into the module and let me know how it behaves afterward.
Okay, I tried flashing the firmware you sent, but the update stalled at 14% and just sat there for hours. I eventually closed ArducamUvcFWUpdateTool and tried again, but now the PC doesn’t recognize the camera at all. Did the failed flash corrupt the module? Is there some kind of reset I can do so I can start over?
Adding a bit more detail: the upgrade stayed stuck at 14% for a long time, so I quit ArducamUvcFWUpdateTool and retried, and now the camera isn’t detected by the PC anymore. I’m not sure if there’s a way to reset it so I can retry the flash. Also, can you clarify what’s actually inside that firmware file - does it contain all the optimized low-light settings, or only the increased manual exposure scale? I remember the B0545 (also IMX585-based) is tuned for challenging low-light conditions but it doesn’t have a USB interface.
That failure pattern - stuck at 14% and then dropping off the USB bus - usually means the module is bricked and needs manual recovery. I’ve sent you the remote support details through private message so we can connect and try to unbrick it. Just pick a convenient time and send me the access details from the remote tool. Note our timezone is UTC+8 (Beijing/Hong Kong time), and the 22:00 slot is only for sales, not remote support. Also, to answer the performance question: the B0498 and B0545 present the same low-light performance.
Thanks, that parity confirmation matters a lot for my use case. The plan is a night vision camera on a boat to help with nighttime navigation, and I’m going to build a custom waterproof enclosure for the module. I chose the IMX585 after researching its large sensor size, large pixel size, and high sensitivity - Sony’s drive recorder page was my main reference. I’ll accept the remote support and book a time so we can unbrick the camera.
Sounds good - once you’ve booked a slot and sent over the remote access details, we’ll get the module recovered and then you can retry the firmware with the increased manual exposure scaling. To recap where things stand: the firmware only increases the manual exposure scale (not a full low-light tune), and the B0498 and B0545 have the same low-light performance. Separately, if you’re into creative imaging projects, we run an Arducam Active Use (AAU) program - you can share project ideas, ask technical questions, or join our Discord community for updates. Discord invite: Discord
