Amazon -
Arducam 16 MP, IMX519 (unable to put a link since I’m new) -
Raspberry Pi Zero W -
How To Use Arducam 16MP Camera On Rapberry Pi - Arducam -
Focusing doesn’t work, manual or autofocus -
[ 0.000000] Linux version 5.15.61+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1579 Fri Aug 26 11:08:59 BST 2022
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] Reserved memory: created CMA memory pool at 0x0bc00000, size 256 MiB
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i smsc95xx.macaddr=B8:27:EB:AB:14:B2 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyS0,115200 console=tty1 root=PARTUUID=4a6c0ed8-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Memory: 177188K/458752K available (9029K kernel code, 1335K rwdata, 2944K rodata, 436K init, 546K bss, 19420K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 31886 entries in 94 pages
[ 0.000000] ftrace: allocated 94 pages with 5 groups
[ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000098] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000206] bcm2835: system timer (irq = 27)
[ 0.001122] Console: colour dummy device 80x30
[ 0.001802] printk: console [tty1] enabled
[ 0.001913] Calibrating delay loop… 697.95 BogoMIPS (lpj=3489792)
[ 0.060378] pid_max: default: 32768 minimum: 301
[ 0.060647] LSM: Security Framework initializing
[ 0.061025] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.061121] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.063533] cgroup: Disabling memory control group subsystem
[ 0.064043] CPU: Testing write buffer coherency: ok
[ 0.066441] Setting up static identity map for 0x8220 - 0x8258
[ 0.068038] devtmpfs: initialized
[ 0.082419] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.082879] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.082983] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.125618] pinctrl core: initialized pinctrl subsystem
[ 0.128063] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.133015] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.139768] audit: initializing netlink subsys (disabled)
[ 0.140488] audit: type=2000 audit(0.130:1): state=initialized audit_enabled=0 res=1
[ 0.141872] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.142937] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.143051] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.143395] Serial: AMBA PL011 UART driver
[ 0.157965] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.191086] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-08-26T14:04:36, variant start
[ 0.201121] raspberrypi-firmware soc:firmware: Firmware hash is 102f1e848393c2112206fadffaaf86db04e98326
[ 0.261645] Kprobes globally optimized
[ 0.273445] bcm2835-dma 20007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.277026] SCSI subsystem initialized
[ 0.277609] usbcore: registered new interface driver usbfs
[ 0.277791] usbcore: registered new interface driver hub
[ 0.277969] usbcore: registered new device driver usb
[ 0.278577] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.279004] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.279566] pps_core: LinuxPPS API ver. 1 registered
[ 0.279630] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.279729] PTP clock support registered
[ 0.282800] clocksource: Switched to clocksource timer
[ 0.384475] VFS: Disk quotas dquot_6.6.0
[ 0.384698] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.385011] FS-Cache: Loaded
[ 0.385491] CacheFiles: Loaded
[ 0.386677] simple-framebuffer 1eaa9000.framebuffer: framebuffer at 0x1eaa9000, 0x151800 bytes
[ 0.386782] simple-framebuffer 1eaa9000.framebuffer: format=a8r8g8b8, mode=720x480x32, linelength=2880
[ 2.200283] Console: switching to colour frame buffer device 90x30
[ 2.209370] simple-framebuffer 1eaa9000.framebuffer: fb0: simplefb registered!
[ 2.234397] NET: Registered PF_INET protocol family
[ 2.238415] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 2.243989] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 2.251367] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 2.255511] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 2.259664] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 2.263841] TCP: Hash tables configured (established 4096 bind 4096)
[ 2.268092] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 2.272162] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 2.276782] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 2.282344] RPC: Registered named UNIX socket transport module.
[ 2.286489] RPC: Registered udp transport module.
[ 2.290407] RPC: Registered tcp transport module.
[ 2.294279] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.300131] armv6-pmu arm-pmu: hw perfevents: no irqs for PMU, sampling events not supported
[ 2.308081] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 2.360834] Initialise system trusted keyrings
[ 2.365663] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 2.383427] zbud: loaded
[ 2.390711] FS-Cache: Netfs ‘nfs’ registered for caching
[ 2.396202] NFS: Registering the id_resolver key type
[ 2.400270] Key type id_resolver registered
[ 2.404326] Key type id_legacy registered
[ 2.408320] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.412131] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 2.418269] Key type asymmetric registered
[ 2.422034] Asymmetric key parser ‘x509’ registered
[ 2.425927] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.429657] io scheduler mq-deadline registered
[ 2.433310] io scheduler kyber registered
[ 2.452078] bcm2835-rng 20104000.rng: hwrng registered
[ 2.456674] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 2.466280] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 2.494201] brd: module loaded
[ 2.512608] loop: module loaded
[ 2.517867] Loading iSCSI transport class v2.0-870.
[ 2.524886] usbcore: registered new interface driver smsc95xx
[ 2.528760] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.261243] Core Release: 2.80a
[ 3.265002] Setting default values for core params
[ 3.268542] Finished setting default values for core params
[ 3.472388] Using Buffer DMA mode
[ 3.475945] Periodic Transfer Interrupt Enhancement - disabled
[ 3.479445] Multiprocessor Interrupt Enhancement - disabled
[ 3.482968] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.486517] Dedicated Tx FIFOs mode
[ 3.491612] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = cbd04000 dma = 0x8bd04000 len=9024
[ 3.502007] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.518579] dwc_otg: Microframe scheduler enabled
[ 3.518853] WARN::hcd_init_fiq:457: FIQ on core 0
[ 3.525200] WARN::hcd_init_fiq:458: FIQ ASM at c068c7f4 length 36
[ 3.531235] WARN::hcd_init_fiq:497: MPHI regs_base at dc810000
[ 3.537453] dwc_otg 20980000.usb: DWC OTG Controller
[ 3.540667] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 3.544038] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 3.547247] Init: Port Power? op_state=1
[ 3.550350] Init: Power Port (0)
[ 3.554037] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 3.560311] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.563706] usb usb1: Product: DWC OTG Controller
[ 3.567010] usb usb1: Manufacturer: Linux 5.15.61+ dwc_otg_hcd
[ 3.570334] usb usb1: SerialNumber: 20980000.usb
[ 3.575085] hub 1-0:1.0: USB hub found
[ 3.578551] hub 1-0:1.0: 1 port detected
[ 3.583266] dwc_otg: FIQ enabled
[ 3.583308] dwc_otg: NAK holdoff enabled
[ 3.583324] dwc_otg: FIQ split-transaction FSM enabled
[ 3.583354] Module dwc_common_port init
[ 3.584018] usbcore: registered new interface driver usb-storage
[ 3.587820] mousedev: PS/2 mouse device common for all mice
[ 3.595967] sdhci: Secure Digital Host Controller Interface driver
[ 3.599358] sdhci: Copyright(c) Pierre Ossman
[ 3.603466] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.608765] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.613135] hid: raw HID events driver (C) Jiri Kosina
[ 3.616851] usbcore: registered new interface driver usbhid
[ 3.620263] usbhid: USB HID core driver
[ 3.631489] Initializing XFRM netlink socket
[ 3.635559] NET: Registered PF_PACKET protocol family
[ 3.639209] Key type dns_resolver registered
[ 3.643698] registered taskstats version 1
[ 3.647015] Loading compiled-in X.509 certificates
[ 3.670564] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 3.674257] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 3.685588] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.689839] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.696144] mmc-bcm2835 20300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.699620] mmc-bcm2835 20300000.mmcnr: DMA channel allocated
[ 3.733049] sdhost: log_buf @ 6af80858 (8bd03000)
[ 3.785967] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.815158] of_cfs_init
[ 3.819219] of_cfs_init: OK
[ 3.825738] Waiting for root device PARTUUID=4a6c0ed8-02…
[ 3.867864] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.874733] mmc0: new high speed SDHC card at address 0001
[ 3.879880] mmcblk0: mmc0:0001 GB1QT 29.8 GiB
[ 3.889428] mmcblk0: p1 p2
[ 3.894764] mmcblk0: mmc0:0001 GB1QT 29.8 GiB
[ 3.943423] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.950572] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.964057] devtmpfs: mounted
[ 3.974407] Freeing unused kernel image (initmem) memory: 436K
[ 3.978152] Kernel memory protection not selected by kernel config.
[ 3.985200] mmc1: new high speed SDIO card at address 0001
[ 3.989947] Run /sbin/init as init process
[ 3.993743] with arguments:
[ 3.993766] /sbin/init
[ 3.993782] with environment:
[ 3.993795] HOME=/
[ 3.993809] TERM=linux
[ 4.656782] systemd[1]: System time before build time, advancing clock.
[ 5.003763] NET: Registered PF_INET6 protocol family
[ 5.010239] Segment Routing with IPv6
[ 5.014121] In-situ OAM (IOAM) with IPv6
[ 5.137350] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 5.150193] systemd[1]: Detected architecture arm.
[ 5.188604] systemd[1]: Set hostname to .
[ 8.273383] systemd[1]: Queued start job for default target Multi-User System.
[ 8.291000] systemd[1]: Created slice system-getty.slice.
[ 8.303874] systemd[1]: Created slice system-modprobe.slice.
[ 8.315878] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 8.327274] systemd[1]: Created slice User and Session Slice.
[ 8.337401] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 8.347654] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.359867] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.374786] systemd[1]: Reached target Local Encrypted Volumes.
[ 8.385465] systemd[1]: Reached target Network (Pre).
[ 8.395439] systemd[1]: Reached target Paths.
[ 8.405562] systemd[1]: Reached target Slices.
[ 8.415621] systemd[1]: Reached target Swap.
[ 8.427543] systemd[1]: Listening on Syslog Socket.
[ 8.438860] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 8.449451] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 8.461973] systemd[1]: Listening on Journal Audit Socket.
[ 8.473740] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.485504] systemd[1]: Listening on Journal Socket.
[ 8.498920] systemd[1]: Listening on udev Control Socket.
[ 8.509635] systemd[1]: Listening on udev Kernel Socket.
[ 8.521020] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 8.539280] systemd[1]: Mounting POSIX Message Queue File System…
[ 8.593684] systemd[1]: Mounting RPC Pipe File System…
[ 8.637271] systemd[1]: Mounting Kernel Debug File System…
[ 8.692951] systemd[1]: Mounting Kernel Trace File System…
[ 8.724110] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 8.766586] systemd[1]: Starting Restore / save the current clock…
[ 8.824650] systemd[1]: Starting Set the console keyboard layout…
[ 8.894670] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 8.958619] systemd[1]: Starting Load Kernel Module configfs…
[ 9.070639] systemd[1]: Starting Load Kernel Module drm…
[ 9.176162] systemd[1]: Starting Load Kernel Module fuse…
[ 9.220592] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 9.316657] systemd[1]: Starting File System Check on Root Device…
[ 9.494584] systemd[1]: Starting Journal Service…
[ 9.630129] fuse: init (API version 7.34)
[ 9.664602] systemd[1]: Starting Load Kernel Modules…
[ 9.814543] systemd[1]: Starting Coldplug All udev Devices…
[ 10.011050] systemd[1]: Mounted POSIX Message Queue File System.
[ 10.109512] systemd[1]: Mounted RPC Pipe File System.
[ 10.200342] systemd[1]: Mounted Kernel Debug File System.
[ 10.307208] systemd[1]: Mounted Kernel Trace File System.
[ 10.417024] systemd[1]: Finished Restore / save the current clock.
[ 10.469377] i2c_dev: i2c /dev entries driver
[ 10.523212] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 10.600592] systemd[1]: [email protected]: Succeeded.
[ 10.652368] mc: Linux media interface: v0.10
[ 10.689159] systemd[1]: Finished Load Kernel Module configfs.
[ 10.732460] systemd[1]: [email protected]: Succeeded.
[ 10.833315] systemd[1]: Finished Load Kernel Module drm.
[ 10.896631] systemd[1]: [email protected]: Succeeded.
[ 10.963813] systemd[1]: Finished Load Kernel Module fuse.
[ 11.086545] systemd[1]: Mounting FUSE Control File System…
[ 11.299237] videodev: Linux video capture interface: v2.00
[ 11.343670] systemd[1]: Mounting Kernel Configuration File System…
[ 11.365439] ak7375: loading out-of-tree module taints kernel.
[ 11.504034] systemd[1]: Started File System Check Daemon to report status.
[ 11.633196] systemd[1]: Finished File System Check on Root Device.
[ 11.683144] systemd[1]: Finished Load Kernel Modules.
[ 11.747406] systemd[1]: Mounted FUSE Control File System.
[ 11.807972] systemd[1]: Mounted Kernel Configuration File System.
[ 11.934467] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 12.054635] systemd[1]: Starting Apply Kernel Variables…
[ 12.228867] systemd[1]: Started Journal Service.
[ 13.083283] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 13.652065] systemd-journald[103]: Received client request to flush runtime journal.
[ 19.075540] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.078477] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 19.078538] [vc_sm_connected_init]: start
[ 19.123620] [vc_sm_connected_init]: installed successfully
[ 19.520914] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.550330] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.694949] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.857842] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.882992] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.927781] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 19.954604] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 19.957832] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 19.958639] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 19.958721] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 19.958772] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 19.958813] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 19.958850] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 19.978742] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 19.981144] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 19.985021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 19.996590] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 19.996677] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 19.996726] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 19.996787] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 19.996843] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 20.022930] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 20.126047] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 20.235106] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 20.235217] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 20.256657] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 20.256764] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 20.277617] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 20.277724] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 20.332545] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 20.332653] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 20.342263] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 20.342370] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 20.598378] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 20.601155] bcm2835_audio bcm2835_audio: there is not valid maps for state default
[ 21.593697] i2c i2c-11: Added multiplexed i2c bus 0
[ 21.643800] i2c 10-001a: Fixing up cyclic dependency with 20801000.csi
[ 21.713687] i2c i2c-11: Added multiplexed i2c bus 10
[ 29.373231] uart-pl011 20201000.serial: no DMA platform data
[ 29.817775] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 31.341625] 8021q: 802.1Q VLAN Support v1.8
[ 33.334717] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 33.935605] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 33.956177] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 34.402967] cam-dummy-reg: disabling
[ 35.270360] Bluetooth: Core ver 2.22
[ 35.270548] NET: Registered PF_BLUETOOTH protocol family
[ 35.270568] Bluetooth: HCI device and connection manager initialized
[ 35.270605] Bluetooth: HCI socket layer initialized
[ 35.270627] Bluetooth: L2CAP socket layer initialized
[ 35.270674] Bluetooth: SCO socket layer initialized
[ 35.353362] Bluetooth: HCI UART driver ver 2.3
[ 35.353410] Bluetooth: HCI UART protocol H4 registered
[ 35.353555] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 35.353884] Bluetooth: HCI UART protocol Broadcom registered
[ 36.517107] tun: Universal TUN/TAP device driver, 1.6
[ 37.056729] checking generic (1eaa9000 151800) vs hw (0 ffffffff)
[ 37.056773] fb0: switching to vc4 from simple
[ 37.163411] Console: switching to colour dummy device 80x30
[ 37.188153] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 37.188739] vc4-drm soc:gpu: bound 20400000.hvs (ops vc4_hvs_ops [vc4])
[ 37.217314] Registered IR keymap rc-cec
[ 37.217629] rc rc0: vc4 as /devices/platform/soc/20902000.hdmi/rc/rc0
[ 37.217944] input: vc4 as /devices/platform/soc/20902000.hdmi/rc/rc0/input0
[ 37.281319] vc4-drm soc:gpu: bound 20400000.hvs (ops vc4_hvs_ops [vc4])
[ 37.304401] Registered IR keymap rc-cec
[ 37.304704] rc rc0: vc4 as /devices/platform/soc/20902000.hdmi/rc/rc0
[ 37.305021] input: vc4 as /devices/platform/soc/20902000.hdmi/rc/rc0/input1
[ 37.368733] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 37.369012] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,model-zero-w.bin failed with error -2
[ 37.380520] usbcore: registered new interface driver brcmfmac
[ 37.381012] vc4-drm soc:gpu: bound 20400000.hvs (ops vc4_hvs_ops [vc4])
[ 37.402627] Registered IR keymap rc-cec
[ 37.403060] rc rc0: vc4 as /devices/platform/soc/20902000.hdmi/rc/rc0
[ 37.403399] input: vc4 as /devices/platform/soc/20902000.hdmi/rc/rc0/input2
[ 37.653830] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 37.654055] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 37.667224] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897
[ 41.216097] vc4-drm soc:gpu: bound 20400000.hvs (ops vc4_hvs_ops [vc4])
[ 41.265839] Registered IR keymap rc-cec
[ 41.266159] rc rc0: vc4 as /devices/platform/soc/20902000.hdmi/rc/rc0
[ 41.266481] input: vc4 as /devices/platform/soc/20902000.hdmi/rc/rc0/input3
[ 41.294464] vc4-drm soc:gpu: bound 20902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 41.301576] vc4-drm soc:gpu: bound 20004000.txp (ops vc4_txp_ops [vc4])
[ 41.302431] vc4-drm soc:gpu: bound 20206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 41.308433] vc4-drm soc:gpu: bound 20207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 41.309341] vc4-drm soc:gpu: bound 20807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 41.309930] vc4-drm soc:gpu: bound 20c00000.v3d (ops vc4_v3d_ops [vc4])
[ 41.365483] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 41.365652] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[ 41.416104] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 41.416147] Bluetooth: BNEP filters: protocol multicast
[ 41.416182] Bluetooth: BNEP socket layer initialized
[ 41.562234] NET: Registered PF_ALG protocol family
[ 43.453809] imx519 10-001a: Device found is imx519
[ 43.498078] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 44.834505] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 46.258921] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 48.093390] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 51.683510] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
Clean install of Bullseye and re-install all packages from scratch following guides and forum. -
I am unable to focus the camera. I have tried using the --autofocus option, the manual FocuserExample.py script, and directly changing focus_absolute with v4l2-ctl but the focus does not change. If I use the --autofocus option and then check with the FocuserExample.py script, the number has changed and I can verify this by checking with v4l2-ctl too but the image itself looks identical with no change focus. Otherwise I’m able to use the libcamera apps without issue.
