Arducam IMX519 dual cameras not working on Jetson Orin NX with Jetpack 5.1.3
Hi everyone, I’m stuck with two Arducam IMX519 camera modules on a Jetson Orin NX and could use some help. I originally set up Jetpack 5.1.3 with the Arducam IMX519 installer. In dmesg both cameras show up as hardware, so the modules seem detected, but only one camera module produces any video output — sensor0 doesn’t work while sensor1 does. The thing is they should run together at the same time, but right now they don’t even work separately.
Thanks for posting. A couple of questions to narrow this down: which tools did you use to test the video output, and can you paste the relevant dmesg lines showing both IMX519 sensors being probed? Also, what does ls /dev/video* show?
I tested with v4l2, nvgstcapture-1.0 and gst-launch-1.0. All three give the same result — sensor1 produces frames, sensor0 gives nothing. dmesg clearly shows both camera modules’ hardware being detected, so the hardware is there but only one side ever gets a usable stream. That’s the part that confuses me.
Understood. On Jetpack 5.1.3 with the Arducam installer, both sensors appearing in dmesg but only one producing output usually points to the device tree or the driver binding for one of the CSI ports. Could you check which driver/module is bound to each camera in dmesg and confirm the /dev/video node mapping? That will help us see whether sensor0 is actually being assigned a node.
While digging into that, I also tried a different setup. I installed Jetpack 5.1.2 on the Orin NX using the package image v4. But on boot the Orin NX tries to load the imx219 camera modules instead of the imx519 modules. So it’s looking for the wrong sensor entirely. After that I tried running the Arducam IMX519 installer on 5.1.2, and it crashes during installation.
Got it. Could you attach the installer log from the 5.1.2 attempt? The crash during install plus the imx219 modules being loaded on boot are both worth looking at. Also, are you hoping to stay on 5.1.2, or is 5.1.3 the target?
Here’s the log from the crashing installer on Jetpack 5.1.2: https://cdn.arducam.com/forum/0eb1db54b6c7d62905cc6668586639b5/imx519-jetpack512-error.txt
Honestly I’d prefer to get this working on Jetpack 5.1.3, since that’s where both cameras at least show up in dmesg.
Thanks for the log. Quick summary of where things stand so far: on 5.1.2 with package image v4 the system loads imx219 modules instead of imx519, and the Arducam IMX519 installer crashes. On 5.1.3 with the Arducam installer, dmesg sees both IMX519 cameras, but only sensor1 produces video output — sensor0 doesn’t work, and they don’t work separately either. The dual IMX519 issue with sensor0 dead and sensor1 working is still under investigation. I don’t have a fix yet.
Okay, thanks. I’ll stick with 5.1.3 for now then and wait for an update on the sensor0 issue.
Appreciate it. I’ve opened a dedicated thread for this and we can continue the discussion there: Imx519 on Orin NX with dual camera on ports sensor0 doesn't work, but sensor1 does? - #2 by Dion
To recap the current conclusion: the problem is specific to IMX519 dual cameras on Orin NX ports, where sensor0 doesn’t work but sensor1 does. On Jetpack 5.1.2 the system incorrectly loads imx219 modules, while on 5.1.3 both cameras appear in dmesg but only one produces video output. Root cause is still being investigated — I’ll update the thread once we have more.
