Hi, I’m trying to get an Arducam IMX519 autofocus camera working on a Jetson TX2 NX. I followed the native camera quick start guide (the 16MP IMX519 section), but the driver install script dies with: “Cannot find the corresponding deb package, please send the following information to [email protected]”. Has anyone run into this before?
Could you post your kernel version and exact Jetson model? Also which guide URL you used. That error usually means the script couldn’t match your board/L4T combination to a package, so those details matter.
Sure. Kernel is 4.9.337-tegra-32.7.4-20230608211515. cat /proc/device-tree/model shows lanai-3636 (TX2 NX). I used Quick-Start-Guide - Arducam Wiki . The full error is exactly: Cannot find the corresponding deb package, please send the following information to [email protected]
Thanks. That matches a Jetson TX2 NX on L4T 32.7.4. Let me check the supported platform list for the IMX519.
OK, so I checked the product page. The Arducam IMX519 is not supported on the Jetson TX2 NX. That’s why the installer can’t find a deb package — there’s no matching driver package for lanai-3636. The script isn’t failing because of something you did; the platform just isn’t in the supported list.
That’s disappointing. So there’s no way to use this camera on the TX2 NX at all? No older package or manual build?
Correct, there’s no driver package or supported path for the IMX519 on the TX2 NX. I don’t have a workaround for that platform. For anyone hitting this, double-check compatibility before installing the driver — TX2 NX is not a supported platform for this camera.
