Hi, I’m trying to get a B0388 IMX519 Autofocus Camera working on my Jetson Nano and the driver install keeps dying partway through. The installer throws:
dpkg: error processing package arducam-nvidia-l4t-kernel (–install):
Anyone seen this before? Not sure if it’s a bad download or something with my setup.
Can you post your L4T version string (or uname -a output)? Also which board/camera and which install script version you used. That error usually points to the dtoverlay step, so the version info matters.
Thanks, that confirms it. This is a known Jetpack 4.6.2 issue, not the camera or the driver itself. The cboot in L4T 32.7.2 fails to read extlinux.conf, which is why the dtoverlay install breaks and the arducam-nvidia-l4t-kernel post-installation script exits with 255.
Right. The dpkg postinst failure (exit 255) and the dtoverlay error are caused by the 4.6.2 cboot bug, not by the B0388 or the ArduCAM driver itself. Flash 4.6.1, install the driver, and test again. If it still fails at the same step after that, post the new output and we’ll dig further.
