Arducam IMX477 UVC Camera Adapter Board B0278 Color correction
Amazon
B0278
Linux
paper
depends
Hi!
the adapter board overall seems to work pretty well on Linux. However there’s a color/white balance issue that I’m looking to solve: the picture is very blue\cold. Switching from auto white balance I can’t get a decent picture either although I did get it to be a little better. What other color correction options are there in my case? I don’t think changing v4l2 hue/saturation settings is going to help much. Thanks
discuss the resolution on forum
The current awb effect is debugged in a standard light box based on the Planck color temperature. If users have special needs, You can turn off the automatic white balance and turn on the manual white balance to achieve the desired effect by fine-tuning based on the current color temperature.
So configure manually is the ONLY option to get a normal color image on linux. kindof a shame tbh. Will post it how did we solve the problem, seems like a rabbithole
