Hi everyone, hoping someone can help. I’ve got an Arducam IMX477 High Quality IR-CUT Camera (12.3MP, 1/2.3" 477P HQ Camera Module with 6mm CS Lens) hooked up to my Raspberry Pi 4. The Pi does detect the camera, but when I open the camera window the screen just stays black. No image at all. It actually worked briefly when I first set it up, then it stopped working properly and now I only get a black screen whenever I open the camera window. Not sure what changed.
That is a strange one, especially since it worked briefly. A couple of quick questions so we can narrow it down: what OS are you running on the Pi 4, and how exactly are you opening the camera window (libcamera preview, raspistill, a script, etc.)? Also, just to rule out the obvious - is the lens cap removed?
Lens cap is off, yes. I followed the Arducam setup instructions from a YouTube video for the IMX477 and mostly use the preview command to open the camera window. I’ve also spent a lot of time going through YouTube and various forums trying to find a fix, but nothing has worked so far. The camera shows up as detected, it’s just the preview that’s black.
Thanks for the details. The fact that it was detected and worked briefly, then only shows black, points toward either a hardware connection issue or a configuration problem. Before we go deeper, could you post a couple of photos of the connection - one at the Raspberry Pi end and one at the camera end? Also, please run the Arducam bug report tool so we can look at the system diagnostics. The output file contains a lot of useful info about camera detection, i2c, and the current config.
I can take the photos, no problem. Which bug report tool do you mean though? I haven’t run one before.
Here’s the tool. Reboot your Pi first, then run these commands one by one:
Download the tool:
Make it executable:
Then run it:
It will create a file called arducam-bug-report.txt in the current directory. Send that file over along with the connection photos and we can start digging into what’s going on.
Got it, I’ll run through those commands and grab the txt file. I’ll post the photos of both ends of the connection too once I’ve taken them.
Sounds good. To sum up where we are: the camera is detected but the preview is black after having worked briefly, and the root cause isn’t confirmed yet. We still need the arducam-bug-report.txt output and the hardware connection photos to diagnose it properly. Once you post those, we’ll go through the report to check the camera detection status, i2c communication, and the driver/config setup. That should point us toward whether this is a loose connection, a config issue, or something else.
