UCTRONICS : New Order #1000029680 - Model number of the product(s)?
Arducam 12MP 477P Motorized Focus High Quality Camera for Jetson Nano/Xavier NX and NVIDIA Orin NX/AGX Orin
SKU: B0273
Seeed Studios reComputer J1010 Jetson nano
Jetpack 4.6.3
The problem i am having is when i do the memory expansion the camera stops working i have two of them attached on the normal emmc boot the cameras work once i do the expansion following the link the camera stops working on reinstalling the driver the nano reboots but the sd card doesn’t mount and the system crashes
i have tried many times reinstalling and re-enabling the sd card but nothing worked and we are running short on memory on the emmc . -
tried installing drivers before memory expansion ( crashing )
then after expansion installed drivers (still crashing )
tried only mounting the rootfs folders like ,/opt ,/usr still after installing the drivers sd card disabled and system crashes -
is there something in the installation script that disables the sd card from mounting again because without the drivers installed the expansion works fine
