Arducam IMX477 camera module driver incompatible with Jetson Xavier NX JetPack 5.1.4
Hi everyone, I’m trying to get an Arducam IMX477 camera module running on a Jetson Xavier NX Developer Kit. I downloaded the driver package ‘arducam-nvidia-l4t-kernel_4.9.140-32.4.3’ but it won’t install. It errors out saying it needs an older version of ‘nvidia-l4t-core’ and my system already has a newer one. Has anyone seen this before?
Welcome! That dependency error usually means the package was built for a different L4T release than what you’re running. Could you share your JetPack/L4T version and the kernel output from ‘uname -r’? Also paste the exact dpkg error if you have it handy.
Sure. I’m on JetPack 5.1.4, L4T 35.6, kernel 5.10.216-tegra. The package I tried is ‘arducam-nvidia-l4t-kernel_4.9.140-32.4.3’ and it’s flagged as incompatible because it depends on an older ‘nvidia-l4t-core’. Is there a compatible driver package for this L4T, or some instructions for building the driver against my current kernel?
Looking at that package name, it targets the older L4T 32.x line (the 4.9.140 kernel era), so it pulls in an old ‘nvidia-l4t-core’ dependency and simply won’t play nice with L4T 35.6 / kernel 5.10.216-tegra. That mismatch is the root cause, not a problem with your install. On the Xavier NX, the IMX477 driver is picky about L4T version, and the recommended route is to run L4T 32.6.1 on the dev kit. Arducam’s Jetson Cameras docs cover the setup here: Introduction to Arducam Jetson Cameras - Arducam Wiki
Okay, so there’s no driver for 5.1.4 / L4T 35.6? Just to confirm, I should reflash the Xavier NX to L4T 32.6.1 and then use the driver package I already have?
Correct. For the Xavier NX Developer Kit, the IMX477 module needs a compatible L4T version, and L4T 32.6.1 is the recommended one. Reflash to L4T 32.6.1 and follow the steps in that documentation link, and the 4.9.140-era driver package should line up with that release. If anything comes up after you reflash, post back with the details and we’ll dig in.
