Hi all, hoping someone can point me in the right direction. I’ve got an Arducam IMX462 camera (B0444) hooked up to a Raspberry Pi 5 8GB running Bookworm. I followed the Pivariety quick start guide over at the Arducam docs site, but when I run libcamera-hello --list-cameras it just says “No cameras available”. The camera has never worked since I got it. It’s the Color Ultra Low Light STARVIS CMOS model if that helps.
I’ve already tried a bunch of stuff on my own. I read through quite a few threads on the Arducam forum and joined their Discord server, posted about the issue there too. I also tried to create a post on the Arducam forum directly, but I kept getting a 403 error every time I tried to submit it, so I couldn’t ask there.
Sorry you’re hitting this. Let’s gather some diagnostics first. Can you take a couple of pictures of the hardware connection - one showing the ribbon cable at the Raspberry Pi end and one at the camera end? Also, please run our bug report tool so I can see what the system is reporting.
Here’s how to generate the bug report:
- Reboot your device.
- Download the tool:
- Make it executable:
- Run it:
This will create an arducam-bug-report.txt file in the current directory. Send that file over along with the photos.
Thanks for the quick reply. I’ve sent the bug report txt and the photos of the cable at both ends via private message. Let me know if you need anything else.
Thanks, got them. Based on the bug report, it looks like the arducam libcamera packages might be outdated or missing. I’ve uploaded the latest arducam libcamera packages and sent you the details in a private message. Once you’ve got them, run the following to install and then test the camera:
./install_pivariety_pkgs.sh -p -l
libcamera-still -t 0
That did the trick! The latest arducam libcamera packages fixed it. I ran the install commands and then libcamera-still -t 0, and the camera works now. I tested it successfully on both my Raspberry Pi 5 and a Raspberry Pi 4 B+. I also updated the Discord thread with the result. Thanks for the help!
