Hi all, I’ve been trying to install the camera driver for an Arducam 2MP Ultra Low Light Starvis IMX462 Motorized IR-Cut Camera on an NVIDIA Jetson Xavier NX, but the install keeps failing. I never got it to work. Hoping someone here has run into this.
Sorry to hear that. Can you share a few details — exact platform, kernel version, and which installation guide you’ve been following? Also the commands you ran and any error output would help.
Sure. Platform is the NVIDIA Jetson Xavier NX Developer Kit. Kernel version is 5.10.104-tegra-35.3.1-20230319081403. I initially followed this manual: https://www.uctronics.com/download/Amazon/B0333_Manual.pdf
That B0333 manual looks like the UCTronics/Raspberry Pi flow, not the Jetson flow. Which commands did you actually run from it? And what errors did you get?
I ran these:
./install_full.sh -m arducam
./install_pivariety_pkgs.sh -p kernel_driver
The pivariety one returns “kernel:5.10.104-tegra unsupported package”. The install_full.sh prints:
“Cannot find the corresponding deb package, please send the following information to [email protected]”
followed by:
Kernel version: 5.10.104-tegra-35.3.1-20230319081403
Jetson type: NVIDIA Jetson Xavier NX Developer Kit
unsupported package
I’ve attached a screenshot of the error too.
That “unsupported package” line from install_pivariety_pkgs.sh confirms you were on the wrong guide — that script is part of the Raspberry Pi / UCTronics instructions, not the Jetson driver install. For a Jetson Xavier NX you want the Arducam Jetvariety Camera Quick Start Guide, specifically the “Install Driver” section: Quick Start Guide - Arducam Wiki
That explains the pivariety script at least. But install_full.sh -m arducam is from the Jetson guide, and that’s the one throwing “Cannot find the corresponding deb package”. So I figured the driver just isn’t compatible with the Xavier NX at all.
Not quite. Let’s look at that error more carefully. The script looks for a prebuilt deb that matches your exact kernel, and it didn’t find one. I checked the supported versions list, and Arducam doesn’t currently release a camera driver for kernel 5.10.104-tegra. That’s why the script can’t find the corresponding deb package — your kernel isn’t on the supported list yet.
Ah, so my kernel is just too new / not supported yet. What can I do in the meantime if I need the camera working?
Right now the workaround is to burn a JetPack version that’s on the supported list if you need the camera before the 5.10.104 driver is out. The driver for your current JetPack/kernel version is expected in about two months. Once it’s released, install_full.sh -m arducam should find the matching deb. To recap: the “unsupported package” error came from following the wrong (RPi) guide, and the “Cannot find the corresponding deb package” error is because 5.10.104-tegra isn’t supported yet.
