Arducam IMX283 camera driver missing for Jetson with JetPack 6.x
I’ve been trying to get the Arducam IMX283 camera (model B0543) working on my Jetson Orin setup and I’m stuck at the very first step — I can’t find a Jetson/Linux driver package for it anywhere.
I’ve searched through the Arducam download site and dug through their GitHub repositories but there’s no driver package for this camera. What’s confusing is that the IMX283 is listed as a partner camera on the NVIDIA Jetson Camera Partner pages, so I’d expect a corresponding driver to exist somewhere.
Has anyone successfully used this camera on Jetson? Am I looking in the wrong place? Running JetPack 6.x on Jetson Orin Nano/NX.
The driver does exist — it’s just not packaged the way you’re expecting.
For the Arducam IMX283 (B0543) on JetPack 6.x with Jetson Orin Nano/NX, the driver is distributed through a unified MIPI Camera installation script rather than as a standalone IMX283-specific driver package. That’s why you couldn’t find it searching for an individual driver.
Here’s how to get it — grab the installer from the ArduCAM MIPI_Camera GitHub releases page:
chmod +x install_full.sh
./install_full.sh -m arducam_4lane
The -m arducam_4lane flag is critical — the IMX283 uses a 4-lane MIPI interface and that mode tells the installer to configure everything correctly for that lane count.
One important caveat: this installer is designed for and only supported on the NVIDIA official developer kit carrier board. If you’re using the dev kit board, you should be good to go.
Appreciate the pointer to the installer, but this is where things get complicated for my setup.
I’m not using the NVIDIA official developer kit carrier board — we’ve designed our own custom/in-house carrier board. The prebuilt installer script isn’t really useful for us because I can’t just run it and expect things to work on custom hardware.
What I actually need is the raw sensor driver source code so I can do proper kernel-level integration. With a custom board I have to modify device tree entries — CSI lane assignments, input clocks, GPIO pin mappings, regulator configurations — all of that is board-specific. The prebuilt installer abstracts all of that away for the dev kit, but for a custom board I need to get my hands dirty at the kernel and device tree level.
Is there any way to get the actual driver source files for the IMX283 rather than just the installer script?
That’s completely understandable — custom carrier board integration is a whole different ballgame compared to running a prebuilt installer on the dev kit.
Before I look into what source files are available, can you confirm your exact environment? Just want to make sure I’m pointing you at the right versions:
  • JetPack 6.x / L4T 36.x?
  • Jetson Orin Nano or NX module?
  • And this is the Arducam IMX283 B0543 specifically?
Once you confirm those I’ll see what I can dig up for source-level access.
Yes, all of that is correct:
  • Jetson Orin Nano/NX
  • Arducam IMX283 B0543 camera
  • Custom/in-house carrier board (definitely not the NVIDIA dev kit)
Based on the install steps you mentioned earlier — the install_full.sh with -m arducam_4lane — the driver clearly exists in compiled form for JetPack 6.x. But for kernel-level integration on a custom board, here’s what I specifically need:
  • imx283.c — the actual sensor driver source
  • Related header files — whatever the driver depends on
  • Device tree examples (.dtsi) — bindings or reference implementations for this sensor
  • Integration notes — anything specific to JetPack 6.x / L4T 36.x that would help with the bring-up
Without these I’m stuck — I can’t properly map the sensor to our board’s CSI lanes, clock tree, GPIOs, and power regulators.
Alright, thanks for confirming all of that. I’ve sent you a private message with the driver source package — that includes imx283.c, the associated headers, and the device tree binding examples for the IMX283 on JetPack 6.x / L4T 36.x. Check your messages and you should have everything to get started.
A few things to watch out for during your custom board bring-up:
  • The sensor uses a 4-lane MIPI CSI interface — your device tree needs to correctly specify the lane mapping for whichever CSI port you’ve routed it to on your carrier board.
  • You’ll need to carefully reconcile your board’s clock tree, GPIO assignments, and regulator mappings against what the driver expects. The reference device tree assumes the dev kit layout, so expect to rework those sections.
  • The power-on sequence and reset GPIO handling in the driver were validated against the NVIDIA dev kit — depending on how your carrier routes the reset line and powers the sensor, you might run into timing issues during probe.
Custom board integration for MIPI sensors can be a bit of a grind — signal integrity, I2C addressing, and clock jitter all come into play. Post back here if you hit specific issues during the kernel-level bring-up and we can work through them.
