Arducam IMX219 camera not working on Raspberry Pi with included cable
Hi, hoping someone can point me in the right direction. I’ve got an Arducam B0103 imx219 camera (RobotShop code RB-Adu-29) and it just won’t work. I’ve tried it on three different Raspberry Pi boards and none of them seem to detect it. I’m not sure if the camera is bad or if I’m missing something obvious.
Thanks for the details. Before we dig in, can you confirm which ribbon cable you’re using? We’ve seen quite a few cases where a non-original cable causes exactly this kind of no-detection problem. The camera ships with a 15-15cm white FFC, and that’s the one it should be used with. If you’re on a different cable, please swap back to the original and test again. Photos of your setup or a short video of the failure would also help us confirm whether the issue is actually the camera itself.
I was using a different cable, honestly didn’t think it would matter. I’ve now switched to the one that came with the camera, but still nothing. How should I get the evidence over to you?
Good, staying on the original cable is important. Here’s the bug report tool so we can capture the camera state and config:
  1. Reboot your Pi.
  2. Download the tool:
  3. Make it executable:
  4. Run it:
It will drop an arducam-bug-report.txt file in the current directory. Please send that file over through private message so it doesn’t get buried in the thread.
Done. I ran the tool and also took photos of the original cable and how it’s connected to the Pi. I’ve sent the report and the pictures over privately.
Thanks, I went through your report and the photos. I can see three separate problems that would stop the camera from working:
  1. The wiring is reversed on the camera module end of the connector.
  2. The connector isn’t seated correctly — the black plastic latch needs to be pushed all the way to the end.
  3. The config is missing dtoverlay=imx219, and camera_auto_detect is still 1 instead of 0.
To fix the config:
sudo nano /boot/firmware/config.txt
Then add dtoverlay=imx219 and change camera_auto_detect=1 to camera_auto_detect=0.
One heads-up: if these three points aren’t corrected, even a brand-new camera won’t work, so let’s sort them first.
Sorry about that, I clearly mishandled a few things. I’ve redone the cable orientation, reseated the connector, and edited the config. New photos and a fresh report have been sent to you.
Got them, thanks. Before I review, can you paste the exact dtoverlay and camera_auto_detect lines from your /boot/firmware/config.txt? I want to make sure the config is exactly right this time.
Ah, I just spotted the mistake. I forgot to add the 0 to camera_auto_detect=0 — I’d left it as camera_auto_detect= with no value. I’ve attached a screenshot of the current config.
Good catch. An empty camera_auto_detect would definitely cause detection to fail. Once you’ve saved camera_auto_detect=0 and rebooted, does the imx219 show up, or are you still hitting problems?
Now I’ve got a different problem. I also run a Global Shutter camera (imx296) on a Raspberry Pi 4, and it stopped working after I installed a fresh Raspberry Pi OS. The Pi itself suggested an update, so I ran it, and after that the imx296 started working again. But when I run the report script with the imx219 attached, it doesn’t generate a report — it just errors out. I’ve sent you a screenshot of the error privately.
Glad the imx296 came back after the OS update — that usually points to a driver/kernel mismatch in the fresh image that the update pulled in. For the imx219 side, the report script erroring instead of producing arducam-bug-report.txt means we can’t capture the camera state right now. I’ve received your error screenshot and I’m looking into it; it could be that the tool needs a tweak on the newer OS, or the imx219 still isn’t enumerating properly. I’ll follow up once I’ve had a closer look.
