ArduCam IMX219 8MP wide-angle camera not working on Jetson Nano
Hi everyone, hoping someone can point me in the right direction. I’ve got an ArduCam IMX219 8MP 1/4" wide-angle camera for the Jetson Nano (B0179) and I’ve never managed to get a single frame out of it. I followed the paper manual and several NVIDIA forum tutorials, but nothing works.
Setup: Jetson Nano on the stock L4T/Ubuntu image. I’ve tried the usual nvarguscamerasrc pipeline:
gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=20/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw,width=960, height=720' ! nvvidconv ! nvegltransform ! nveglglessink -e
I also tried a v4l2 command I found online, and nvgstcapture-1.0 just crashes the system. A Raspberry Pi 2 camera works fine on the same board, so the Nano side isn’t completely dead.
dmesg shows:
[    1.336871] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[    1.361691] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[    1.385052] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.385176] imx219 8-0010: board setup failed
[    1.385258] imx219: probe of 8-0010 failed with error -121
[    1.537796] vi 54080000.vi: subdev imx219 7-0010 bound
[  720.095312] imx219 7-0010: imx219_write_reg: i2c write failed, 0x160 = 9
[  730.348410] imx219 7-0010: Error writing mode
Any ideas?
Thanks for the logs. That -121 error on 8-0010 is an I2C read probe failure, and then the write failures on 7-0010 suggest the sensor isn’t answering consistently on the bus. Before we go deeper, can you post a couple of photos of the physical connection — both the camera end and the Jetson end of the ribbon cable?
Also, please run our bug report tool so we can see the full system state. Reboot first, then:
sudo ./arducam-camera-bug-report-nvidia
That produces an arducam-bug-report.txt in the current directory. Attach it here along with the photos.
Here’s an update. The camera is now being detected (it binds as imx219 6-0010), but streaming still fails — it looks like MIPI calibration is timing out.
System info:
hostname: nano
uname -r: 4.9.253-tegra
OS: Ubuntu 20.04.6 LTS (Focal Fossa)
/etc/nv_tegra_release: # R32 (release), REVISION: 6.1, BOARD: t210ref
v4l-utils: 1.18.0-2build1
ls /dev/video*: /dev/video0
I tried:
timeout 5s v4l2-ctl --set-fmt-video=width=3264,height=2464,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap
and
gst-launch-1.0 nvarguscamerasrc sensor-id=0 num-buffers=1 ! 'video/x-raw(memory:NVMM),format=(string)NV12, width=(int)3264, height=(int)2464,framerate=10/1' ! nvjpegenc ! filesink location=arducam-test.jpg
The gst line failed with:
(gst-launch-1.0:9723): GStreamer-CRITICAL **: 16:26:44.372: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed
WARNING: erroneous pipeline: syntax error
ls arducam-test.jpg: ls: cannot access 'arducam-test.jpg': No such file or directory
dmesg | grep imx:
[    1.303381] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[    1.475552] vi 54080000.vi: subdev imx219 6-0010 bound
Camera-related dmesg:
[  221.073550] video4linux video0: frame start syncpt timeout!0
[... repeated frame start syncpt timeout!0 ...]
[  227.115889] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:74b1, lanes:100000
[  227.123839] tegra_mipi_cal 700e3000.mipical: MIPI_CAL_CTRL                  0x00 0x2a000000
[  227.123844] tegra_mipi_cal 700e3000.mipical: CIL_MIPI_CAL_STATUS            0x08 0x000074b1
[  227.123848] tegra_mipi_cal 700e3000.mipical: CIL_MIPI_CAL_STATUS_2          0x0c 0x00000000
[  227.123853] tegra_mipi_cal 700e3000.mipical: CILA_MIPI_CAL_CONFIG           0x14 0x00200000
[  227.123857] tegra_mipi_cal 700e3000.mipical: CILB_MIPI_CAL_CONFIG           0x18 0x00000000
[  227.123861] tegra_mipi_cal 700e3000.mipical: CILC_MIPI_CAL_CONFIG           0x1c 0x00000000
[  227.124191] tegra_mipi_cal 700e3000.mipical: CILD_MIPI_CAL_CONFIG           0x20 0x00000000
[  227.124196] tegra_mipi_cal 700e3000.mipical: CILE_MIPI_CAL_CONFIG           0x24 0x00000000
[  227.124201] tegra_mipi_cal 700e3000.mipical: CILF_MIPI_CAL_CONFIG           0x28 0x00000000
[  227.124205] tegra_mipi_cal 700e3000.mipical: DSIA_MIPI_CAL_CONFIG           0x38 0x00000000
[  227.124209] tegra_mipi_cal 700e3000.mipical: DSIB_MIPI_CAL_CONFIG           0x3c 0x00000000
[  227.124213] tegra_mipi_cal 700e3000.mipical: DSIC_MIPI_CAL_CONFIG           0x40 0x00000000
[  227.124217] tegra_mipi_cal 700e3000.mipical: DSID_MIPI_CAL_CONFIG           0x44 0x00000000
[  227.124221] tegra_mipi_cal 700e3000.mipical: DSIA_MIPI_CAL_CONFIG_2         0x64 0x00000000
[  227.124225] tegra_mipi_cal 700e3000.mipical: DSIB_MIPI_CAL_CONFIG_2         0x68 0x00000000
[  227.124229] tegra_mipi_cal 700e3000.mipical: DSIC_MIPI_CAL_CONFIG_2         0x70 0x00000000
[  227.124232] tegra_mipi_cal 700e3000.mipical: DSID_MIPI_CAL_CONFIG_2         0x74 0x00000000
[  227.124236] tegra_mipi_cal 700e3000.mipical: MIPI_BIAS_PAD_CFG0             0x58 0x00000000
[  227.124240] tegra_mipi_cal 700e3000.mipical: MIPI_BIAS_PAD_CFG1             0x5c 0x00000000
[  227.124244] tegra_mipi_cal 700e3000.mipical: MIPI_BIAS_PAD_CFG2             0x60 0x00000000
[  227.124250] vi 54080000.vi: mipi calibration failed
[  227.129438] vi 54080000.vi: calibration failed with -110 error
There are also these I2C errors:
tegra-i2c 7000c000.i2c: no acknowledge from address 0x50
tegra-i2c 7000c400.i2c: no acknowledge from address 0x50
I ran the bug report tool and attached photos of both ends of the connection.
Thanks, I’ve reviewed the photos. From what you attached, it looks like you’re running the Nano on a third-party carrier board rather than the official NVIDIA dev kit carrier. That lines up with the logs: the driver binds the sensor, but MIPI calibration never completes, so streaming can’t start. Detection alone doesn’t mean capture will work.
These modules are validated on the official NVIDIA Jetson Nano carrier board. Can you try the camera on the official carrier and see whether the calibration errors disappear?
I went back and double-checked — this actually is the official Jetson Nano dev kit carrier board, not a third-party one. I’ve attached a picture of the full setup. It behaves as if there are no drivers for the camera at all. What else can I try to get it working?
Thanks for confirming. To narrow down whether the fault is in the camera module itself or somewhere on the Nano side, can you test the camera on a Raspberry Pi? If the module is healthy it should be detectable there. If it misbehaves on the Pi too, that points at the module or the cable rather than the Nano.
I have a Raspberry Pi 3B that I use for Klipper with a 3D printer. I tried plugging the camera in, but the Pi won’t boot at all with the camera connected. I can borrow a Pi 4 from a colleague in a few days. In the meantime, what commands or libraries do I actually need to use this camera on a Raspberry Pi?
On the Raspberry Pi this IMX219 needs a bit of config before it will show up. Camera auto-detect doesn’t apply the correct overlay for this module, so you have to disable auto-detect and load the imx219 overlay manually.
Edit the config file — the path depends on your OS:
  • Bullseye: sudo nano /boot/config.txt
  • Bookworm: sudo nano /boot/firmware/config.txt
Change:
camera_auto_detect=1
to:
camera_auto_detect=0
Then scroll to the bottom and add this under the [all] section:
dtoverlay=219
Save and reboot. After that you can check with libcamera (bookworm) or raspistill (bullseye).
I got the Pi 4 and it’s worse. With the camera connected, the Pi 4 doesn’t boot either. So I removed the camera, made the config changes you listed, and rebooted — the camera wasn’t recognized at all. Then I reconnected the camera and rebooted, and the Pi didn’t boot again, and the board got extremely hot. I went back to the Pi 3B and got the exact same result. Any idea what’s going on?
That’s not normal behavior. Before assuming the module is damaged, let’s rule out the ribbon cable — a faulty cable can cause exactly this kind of no-detect/no-stream behavior, and in a bad case a short can stop the board from booting. Do you have another white ribbon cable you can swap in and retest?
I actually have several white cables. I tried about three different ones on the Jetson and they all produce the same failure — the camera is detected but won’t stream, with the same MIPI calibration errors. I’ve attached a picture showing the cables I tested.
Thanks for testing those. So at this point we’ve ruled out the ribbon cable, and the behavior is consistent: the imx219 driver binds on the Nano but MIPI calibration keeps failing with the -110 / frame start syncpt timeout errors, and the Pi won’t boot with the module attached. The issue is still open — we haven’t reached a working configuration yet, and I’ll follow up as soon as there’s a next step.
