As per Aducam document we have followed hardware dtsi modification using jetson-io tool
still we not able see any driver and i used i2cdetct -y 9 we are not able to find camera address so what might be issue. is camera or need to add any driver.
do you have the camera cable connected correctly? it took me 4 days to troubleshoot eventually to figure out that the cable was connected wrong way into my raspberry pi. make sure the pins in your jetson camera port touch the metal side of the cable.
i connected to jetson nano Agix i have installed driver but every time it is failing to communicate so
log:
probe of 9-001a failed with error -121
imx477_board_setup: error during i2c read probe (-121)
did u check the physical connection and can confirm it is properly connected?
yes i have checked i connected to cam0
yeah but did u check that the cable is connected correctly with metal side of the cable touching the pins in the cam0 port not the backside?
also check the same with the other end of cable that goes into the camera
yes i checked its look same what u suggested
