Arducam Driver Package for A603: No DTB found runtime error
I have the A603 board from Seeedstudio with the Orin NX 16GB module and I have flashed using this guide. I am trying to install the Arducam driver package so that I can use the OV9281 stereo camera (SKU: B0337). I get an error that pertains to the DTB file saying it is not found for the Nvidia Dev kit, which is not what I am using.
From the repo, I downloaded the appropriate Orin NX package (5.10.104 & 35.3.1), which is confirmed by the outputs:
alex@orin:~$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
alex@orin:~$ uname -a
Linux orin 5.10.104-tegra #1 SMP PREEMPT Mon Apr 3 11:43:47 CST 2023 aarch64 aarch64 aarch64 GNU/Linux
Upon installing with:
sudo dpkg -i arducam-nvidia-l4t-kernel-t234-nx-5.10.104-tegra-35.3.1-20230725012901_arm64.deb
I get the output with error:
(Reading database ... 228541 files and directories currently installed.)
Preparing to unpack arducam-nvidia-l4t-kernel-t234-nx-5.10.104-tegra-35.3.1-20230725012901_arm64.deb ...
Unpacking arducam-nvidia-l4t-kernel (5.10.104-tegra-35.3.1-20230725012901) over (5.10.104-tegra-35.3.1-20230725012901) ...
Setting up arducam-nvidia-l4t-kernel (5.10.104-tegra-35.3.1-20230725012901) ...
  File "/opt/arducam/jetson-io/config-by-hardware.py", line 125, in <module>
    main()
  File "/opt/arducam/jetson-io/config-by-hardware.py", line 94, in main
    jetson = board.Board()
  File "/opt/arducam/jetson-io/Jetson/board.py", line 230, in __init__
    self.dtb = _board_get_dtb(self.compat, self.model, dtbdir)
  File "/opt/arducam/jetson-io/Jetson/board.py", line 114, in _board_get_dtb
    raise RuntimeError("No DTB found for %s!" % model)
RuntimeError: No DTB found for NVIDIA Orin NX Developer Kit!
dpkg: error processing package arducam-nvidia-l4t-kernel (--install):
I suspect this is an issue where the install script is looking for the DTB file for the Orin NX Developer Kit in particular. I have the DTB files for the A603 board (tegra234-p3767-0000-p3509-a02.dtb and tegra234-p3767-0001-p3509-a02.dtb) from flashing the system, so I believe the solution is to point the arducam driver script to these files. Placing these in /boot/dtb has no effect.
Here is a pastebin of the dmesg
What can I do to install the Arducam drivers on the A603 where the error in installing is due to a DTB conflict? I have the DTB files from when I flashed the system, so I think I need to just specify these files in some manner for the arducam script to utilize which I have failed at thus far.
Any insight is appreciated. Thanks
I was able to bypass the error that I got when installing the arducam kernel package by using the SDK Manager to flash the jetson.
I am able to ls /dev/video* and see the video devices of the stereo camera. However a new issue persists: whenever I access these devices in any way (either by ffplay /dev/video0 or by running the arducam_displayer.py script), I get a significant kernel issue:
Message from syslogd@ubuntu at Aug 28 15:49:16 ...
 kernel:[  266.929512] Internal error: Oops: 96000004 [#1] PREEMPT SMP
I am a bit unfamiliar with DTB. Does this mean that my device tree overlay is insufficient? Do I need to modify this to either add a CSI input or to add the particular camera I am using? Again, this is a new realm for me. I have the DTB files that came with the A603 (tegra234-p3767-0000-p3509-a02.dtb and tegra234-p3767-0001-p3509-a02.dtb). Perhaps this is the missing component.
After flashing the A603 with SDK Manager and installing the arducam driver package, I noticed the splash boot screen states “1: Custom Header Config: ”. This indicates to me that the driver installed correctly and that my camera is acknowledged. I think I am close to getting this camera and the arducam scripts to work.
@Edward, I see you are a part of the support team. Could you provide insight for me please or page someone who might have some suggestions for me? Thank you for your time.
Were you able to solve this problem?
I am stuck at this point right now
Were you able to solve this one?
