Arducam driver. Cannot stat. Not found
Using Kernal 5.10.60
Tech support says not the one the use
They use 5.10
How to get specific version for raspberry pi 4 b
Hi Pimark
5.10.60 is not in the pre-compiled version we provide.
You can refer to chapter 2.2. The second way-Build from the kernel headers in this document to compile the kernel driver:
Yes. So I use the info in 2.2 to make the camera work with 5.10.60?
Yes, according to the operation in the document, you can achieve 5.10.60 to make the camera work
That is exactly what I am trying to do with no luck
After. Promted with a Y/n after 2.2.1. it just says abort
After 2.2.2
modeprobe: FATAL: Module arducam not found in directory /lib/modules/5.10.60-v7l+
Hi @Pimark
May I ask where did you report the error for the first time?
Can you share your terminal output?
Can you try copying one by one instead of copying together?
Can you provide dmesg logs and the content of /boot/config.txt?
It looks like you did not manually edit the /boot/config.txt file
Tip: You need to reboot after editing /boot/config.txt
I rebooted and it now works! Thanks so much
I’ve learned a valuable lesson on copying and pasting. And how to get this driver installed. You dabomb .com(:
Glad to hear that your problem has been solved.
If copying one of the multiple commands takes a long time to execute and it also receives keyboard input, then this problem will occur.
I think we should add more hints to the document.
