Arducam B0506 24/7 standalone recording software confusion
Hey everyone, I’ve got an Arducam B0506 and I’m trying to figure out how to set up 24/7 continuous recording with it. The catch is I want this to run standalone — no computer in the loop at all. I’m a bit overwhelmed by the software side of things and not sure where to even start. Has anyone done something like this with the B0506? What software should I be looking at?
Quick update — I tried playing around with the Arducam GUI Tool and also AMCap, but honestly I can’t wrap my head around how either of these would work for a standalone recording setup. They both seem to expect a Windows PC to be connected the whole time, which defeats the purpose. Am I missing something obvious here or are these just the wrong tools for what I’m trying to do?
You’re not missing anything — both the Arducam GUI Tool and AMCap are designed to run on a Windows PC with the camera connected directly via USB. They won’t help you for a standalone recording setup, so you can rule those out.
To point you in the right direction, I think the key question is: what host platform are you planning to use? The software and library options for the B0506 depend entirely on whether you’re going with a microcontroller or a single-board computer. If you can share what hardware you’re thinking of pairing the camera with, I can give you more targeted recommendations.
Thanks for confirming that — I was going in circles thinking I was just using the tools wrong.
So my preferred setup would be to use an Arduino Uno as the host. That’s what I have on hand and I’m most comfortable with. But if the Uno just isn’t up to the task for 24/7 recording with the B0506, I could fall back to a Raspberry Pi instead.
Also, side issue — I’ve been trying to pull up the blog pages on the Arducam site for setup guides and tutorials, but none of them will load for me. Just spins forever. Not sure if it’s on my end or if the site is having issues.
Glad that cleared things up. Let me address both points.
Regarding the Arduino Uno with the B0506 — this is going to be challenging. The B0506 uses a parallel interface and outputs image data at rates that the Uno’s ATmega328P just isn’t built to handle. The Uno has 2KB of SRAM and runs at 16MHz, which makes capturing, buffering, and writing full video frames to storage in real time extremely difficult — especially for 24/7 continuous recording. It’s not impossible to capture single stills with some work, but continuous video recording isn’t really feasible on that platform.
Raspberry Pi would be a much more realistic path. The B0506 has good support on Pi via the native camera interface or libraries like libcamera / raspistill, and the Pi has the storage I/O and processing power to handle round-the-clock recording. That’s likely where you’ll want to focus your efforts.
As for the blog pages — I haven’t seen widespread reports of the site being down. Could you let me know what browser you’re using and whether you’re seeing any specific error message (timeout, connection refused, etc.)? Might be a regional CDN issue or something on the network side. In the meantime, I can point you toward some alternative resources for the B0506 once you confirm which platform you’re going with.
