Arducam B0433 camera not recognized after serial flash reports success on Raspberry Pi 4
Hi everyone, I’m stuck trying to flash a serial number to an Arducam B0433 UVC camera that I’m using with a Raspberry Pi 4. I followed the official serial number tool guide, and I got one camera to flash fine. But with a second camera of the exact same model, the tool says ‘flashed successfully’ every time, yet when I read it back it still shows the original factory serial. Has anyone seen this where the write reports success but nothing actually changes?
That’s a strange one — if the read-back still shows the factory serial, the write isn’t actually taking. Can you try the alternative flashing software? I’ve sent you the download link through private message. Give that version a try and let me know if the read-back changes.
Thanks. Quick update and a bigger problem: the original flashing tool has now bricked several cameras. Two got bricked on one computer, and one on a different computer (that one was using the tool downloaded straight from the Arducam website). Each time the software said the serial flashed successfully, then the camera disconnected and Windows no longer recognized it as a camera at all. So now I can’t even read or write to those.
Sorry to hear that — let’s recover the bricked modules first. I’ve sent you a guide video over private message that walks through burning fresh firmware onto the bricked camera module. Also, when you use ArducamUVCSerialNumber.exe, make sure you click Read first, and only then modify the serial number/name. Skipping the Read step seems to be part of why writes don’t stick.
I tried the video procedure and the alternative tool. It’s still not writing the serial. On the plus side, it hasn’t bricked any more cameras. The other issue is the firmware tool doesn’t show the bricked camera at all — it’s like the camera isn’t there. I posted a screenshot and a short video showing what I’m seeing.
Let’s reset how Windows sees the camera. Open Device Manager, find the USB camera, right-click and uninstall the driver, then physically unplug the camera and plug it back in. After it re-enumerates, check whether the serial number is actually modified. Sometimes the driver caches the old serial and it looks unchanged even after a successful write.
Still no luck. The serial stays as SN20230215V0, which I understand is the default hardcoded serial on all these cameras. I’ve uninstalled the USB camera driver in Device Manager and modified the serial again — no change. I also re-flashed the camera using the firmware in B0433.7z, then uninstalled and unplugged/replugged — still SN20230215V0. I even tested on a second computer to rule out the first one. The flashing tool does show the firmware info on the camera and the file it flashed from B0433.7z, so it is talking to the camera. Oddly, the one time it worked, I entered the serial and hit Write without clicking Read first. I’ve since tried both Read-first and direct Write and can’t reproduce that initial success.
This is going to be hard to pin down without seeing it live. I’ve sent you remote support details through private message — please check your messages and we can troubleshoot together. Just a heads up, working hours are 8:30 am to 5:30 pm Hong Kong Time.
I’ve installed TeamViewer and I’m ready whenever. Just tell me what you need from me.
Great. I’ve sent you a meeting link through private message — join when you’re ready and we’ll take a look at the live behavior together.
See attached.
Thanks for that. Since the bricked modules aren’t being detected normally, we need to force them into a recoverable state. Here’s the hardware recovery procedure:
  1. Locate the marked pins on the camera module.
  2. Short those marked pins with a jumper wire or tweezers.
  3. While holding the short, connect the camera module to the PC.
  4. Once the PC starts trying to detect the camera module, remove the jumper wire/tweezers.
  5. If it works, the module will show up as ‘PC Camera’ in Device Manager.
  6. At that point, use the firmware flash tool to burn the firmware into the camera module.
That should get the bricked ones back to a flashable state. For the serial that won’t change from SN20230215V0 on the non-bricked camera, we’re still investigating — I’ll follow up once we’ve reproduced it.
