Arducam B0371 IMX519 Autofocus Camera Not Working on Raspberry Pi – RMA
Hi all, I’ve got an Arducam B0371 IMX519 autofocus camera module connected to a Raspberry Pi and it’s not being detected at all. I’ve already tried a few different config.txt variations, but the Pi still doesn’t see the camera. Anyone have any ideas before I go further down the rabbit hole?
Hi, thanks for the report. Before we get into the config side, can you confirm the failure timeline for this unit? Specifically, did the camera work when you first received it and then stop working after a while, or was it never detected from the moment you got it? That detail changes where we look first.
Sorry, I don’t have that info from the end user yet. All I know is the camera had been in their possession for about 5 days before the complaint came in. I’m not sure whether it was tested and working during that window or never detected from day one. I’ll try to get that confirmed.
No problem. While we wait on that, could you grab two things for me? First, photos of the physical connection at both ends - the Raspberry Pi camera connector and the camera module side. Second, the output of this command:
cat /boot/firmware/config.txt
That will show what overlays and camera settings are actually active right now.
Here’s the current config.txt. I’ve been through a bunch of possibilities already, so some lines are commented out or left over from testing:
http://rptl.io/configtxt
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
Additional overlays and parameters are documented
/boot/firmware/overlays/README
param=i2c_arm=on
dtparam=i2c_vc=on
#camera_auto_detect=1 #tested
camera_auto_detect=0
dtoverlay=imx519
display_auto_detect=1
Automatically load initramfs files, if found
auto_initramfs=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Don’t have the firmware create an initial video= setting in cmdline.txt.
Use the kernel’s default instead.
disable_fw_kms_setup=1
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
Photobooth
#IN
gpio=5,6,7,8,16,17,20,21,22,26,27=pu
#OUT
gpio=9,10,11,12,18,19,23,24,25=op
Photobooth End
I’ve also attached photos of the Pi end and the camera end. Camera is still not detected with this exact config.
Thanks, got the config and the photo. The key thing I see is that your current setup is manually loading the IMX519 overlay:
dtoverlay=imx519
That’s a valid way to enable this module, but since the Pi still reports no camera, we need to keep the physical connection and the failure timeline in the picture. The photo helps, but I still need the timeline confirmation to decide whether this ever worked.
Right, still not detected. The camera doesn’t show up at all even with the overlay loaded manually. I’m still waiting to confirm whether it ever worked during those first 5 days.
Okay, so to summarize where we are right now: the camera is still reported as not detected, and the root cause hasn’t been pinned down yet. The config currently uses camera_auto_detect=0 with dtoverlay=imx519, which manually loads the IMX519 overlay, so that part of the setup is accounted for. Next, please confirm the failure timeline (did it work initially and then fail, or was it never detected), and make sure we have clear photos of the connection at both the Pi end and the camera end. I already have your config.txt output above. Once those are confirmed, we can go from there.
