Arducam B0350 stereo camera driver install: libcamera says no cameras on Raspberry Pi 3B+
Hi, hoping someone can help. I’m trying to install the driver for the B0350 Arducam 8M Synchronized Stereo Camera Bundle Kit. The camera just isn’t being detected at all — libcamera reports ‘no cameras available’. Where should I start?
Welcome! Let’s get some basics first so we know what we’re working with. Can you tell me:
  • Which board you’re on
  • The OS image and version
  • The kernel version (uname -a)
  • The output of dmesg | grep -i arducam
That’ll tell us whether the sensor is even being probed on the I2C bus.
Sure. Board is a Raspberry Pi 3 Model B Plus Rev 1.3 (Pi3B+). It’s a fresh install of Raspbian 32-bit 5.15 Bullseye.
uname -a gives:
Linux raspberrypi 5.15.32-v7+ #1538 SMP Thu Mar 31 19:38:48 BST 2022 armv7l GNU/Linux
And the sensor shows up as: arducam-pivariety 10-000c, firmware version 0x10003.
Good, the sensor is being seen on I2C, so that’s a positive sign. For 5.15.y kernels you need the matching driver build — the older 5.10 style packages won’t have binaries for your kernel.
Grab it with:
wget https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/Arducam_pivariety_v4l2_v1.0/arducam_kernel_driver_5.15.y.tar.gz
Then:
cd Release/
./install_driver.sh
Reboot when prompted and let me know how it goes.
Hmm, I think my first attempt went sideways before this. I originally used a driver package meant for the 5.10.17 Pi build, and the install script blew up:
arnold@raspberrypi:~ $ cd Release/
./install_driver.sh
Installing Arducam-Pivariety-V4L2-Driver...
install: cannot stat './bin/5.15.32-v7+/arducam.ko': No such file or directory
install: cannot stat './bin/5.15.32-v7+/arducam.dtbo': No such file or directory
reboot now?(y/n):
Also earlier when I extracted the archive I only saw 5.10.x variants:
arnold@raspberrypi:~ $ tar -zxvf arducam_pivariety_v4l2.tar.gz Release/
It had bin folders for 5.10.17 / 5.10.52 / 5.10.60 / 5.10.63 / 5.10.92 — nothing for 5.15.x. That’s why I did a fresh Raspbian install and tried again.
That explains it — the archive you had didn’t include a 5.15.32-v7+ build, so the script had nothing to install. Use the 5.15.y release link above and the install should find ./bin/5.15.32-v7+/arducam.ko. Reboot after, then run these and paste the output:
dmesg | grep arducam
ls /dev/video* -1
v4l2-ctl --list-formats-ext
libcamera-still -t 0
OK, fresh install done and I used the 5.15.y package this time. Here’s dmesg:
arnold@raspberrypi:~ $ dmesg | grep arducam
[   12.327066] arducam: loading out-of-tree module taints kernel.
[   12.342813] arducam-pivariety 10-000c: firmware version: 0x10003
[   12.858767] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
ls /dev/video*:
arnold@raspberrypi:~ $ ls /dev/video* -1
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
Then this one failed:
arnold@raspberrypi:~ $ v412-ctl --list-formats-ext
bash: v412-ctl: command not found
And libcamera-still -t 0 gives:
Made X/EGL preview window
[0:13:03.937046823] [1313]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3424-e68e0f1e
[0:13:03.997184446] [1327]  WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'arducam-pivariety'
[0:13:03.997297138] [1327]  WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[0:13:03.997369870] [1327] ERROR CameraSensor camera_sensor.cpp:551 'arducam-pivariety 10-000c': Camera sensor does not support test pattern modes.
[0:13:04.031467965] [1327] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'raspberrypi'
[0:13:04.031633383] [1327] ERROR IPARPI raspberrypi.cpp:190 Could not create camera helper for arducam-pivariety
[0:13:04.031704916] [1327] ERROR RPI raspberrypi.cpp:1197 Failed to load a suitable IPA library
[0:13:04.032141514] [1327] ERROR RPI raspberrypi.cpp:1129 Failed to register camera arducam-pivariety 10-000c: -22
I’ve attached my config.txt and a couple of screenshots too.
Thanks, that’s a lot to work with. Can you also paste the relevant boot/kernel lines from dmesg and confirm the full kernel string? And double-check that the driver overlay entries in config.txt are actually uncommented (e.g. dtoverlay=arducam-pivariety).
Here you go:
[    0.000000] Linux version 5.15.32-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP Thu Mar 31 19:38:48 BST 2022
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[    8.675198] i2c 10-000c: Fixing up cyclic dependency with 3f801000.csi
[   33.111192] cam-dummy-reg: disabling
Attachments: config.txt, screenshot 1, screenshot 2
Appreciate the details. I went through everything — the driver install logs, the dmesg output, the /dev/video* listing, the format command, the libcamera-still output, and your config.txt. One thing jumped out right away.
Look closely at the command that failed:
That’s v412-ctl — with the digit 1 after the v4. The actual utility is v4l2-ctl, with a lowercase letter l and the number 2 (v4l2 = Video4Linux2). So the command simply doesn’t exist, which is why bash says ‘command not found’. It’s a typo, not a missing package.
Oh wow, I stared at that for ages and completely missed it. Let me fix it:
arnold@raspberrypi:~ $ v4l2-ctl --list-formats-ext
I’ll grab the output and paste it here.
Perfect, go ahead and run:
(letter l, number 2) and send the output back. I’ll also test the same camera on my end tomorrow so we can compare results, and I’ll report back here once I have them. For now the next step is just re-running that corrected command so we can actually enumerate the camera’s formats.
