Arducam B029001 16MP Autofocus USB Camera fickring problem
    Fab to lab
    B029001
    windows
  5. Problems you were having?
    image flickering
@shanmugamani
Dear Customer,
Sorry to hear your issue. In order to help you solve your issue as soon as possible, I need more detail information.
  1. Have you tested it using AMCAP application? If not, please try to test it using amcap.
  2. Do you have extra camera ?
  3. Please attach me your hardware connection.
    Feel free to let me know if you need more help.
Have you tested it using AMCAP application? If not, please try to test it using amcap.?
yes ,but sometime video working ,sometimes black screen comes ,but in devices list arducam name is there.
yes,I have 2 cams , all are same problem
@shanmugamani
OK, This phenomenon is too similar to the insufficient bandwidth or insufficient power supply of the usb port. If possible, you can change to another computer to test. Another point is not to connect to the hub, it is best to connect directly to the PC.
its directly with pc,not any hub. i l try this another pc
@shanmugamani
OK, I will test it using the same camera you are using. If it works normal.I will read the firmware and send it to you.
okay thank you for your response
We have tried the same camera module and it worked well. Please follow the guide video to burn the firmware to your camera in the link below.
thank you, can i use it for linux , ex.(ubuntu) ,if cant kindly share it for ubuntu too.
@shanmugamani
I’m sorry, but currently we only have a Windows version available.
