Hi, I’m trying to get Arducam cameras working on my Jetson AGX Orin Developer Kit and I’m stuck right at the start.
When I run the auto installer from Releases · ArduCAM/MIPI_Camera · GitHub it immediately fails with a kernel version mismatch. Is it actually possible to run MIPI cameras like the B0279 (IMX477) and B0179 (IMX219) on the AGX Orin Developer Kit at all? If yes, what steps do I need? And can both cameras be connected at the same time to the camera connector?
Any pointers would help, I feel like I’m going in circles.
It stops right there with the kernel version mismatch and never goes any further. I haven’t written any code yet, just wanted to get the driver installed first. I tried a couple of the newer installer releases on that GitHub releases page and got the same result every time.
The Jetson type: UNKNOWN line is the interesting one. The installer detects the board and then tries to match it against a list of known platforms/kernel versions. If the board isn’t in that list, you get UNKNOWN and it aborts with the version mismatch, even though your kernel string looks like a normal R34.1.1 L4T build.
Can you do two things:
Confirm the L4T release:
head -1 /etc/nv_tegra_release
cat /proc/device-tree/model
Show what the installer is actually matching against:
Also, in case it matters — I did try plugging in just the B0179 (IMX219) alone on one CSI port, and just the B0279 (IMX477) alone on another, in case it was a multi-camera problem. Exactly the same failure both times, so it doesn’t seem related to which camera is connected.
That confirms what I suspected — it’s failing before it ever gets to the camera, so the cabling/wiring isn’t the issue.
The installer’s platform table only contains the Jetson Nano and Jetson NX entries. Your board reports as an AGX Orin Dev Kit on L4T R34.1.1, which simply isn’t in that table, so the detection falls through to UNKNOWN and the script stops. That’s why you see the kernel version mismatch rather than a driver error.
I’ll check with the team on the current status of Orin support, but based on the release notes I can see, support is still in development. Give me a moment.
At the moment the MIPI camera drivers for the B0279 (IMX477) and B0179 (IMX219) only support the Jetson Nano and Jetson NX. The Jetson AGX Orin Developer Kit is not supported yet — that’s the actual cause of the Jetson type: UNKNOWN / kernel version mismatch you’re hitting. It’s not something you can work around with a different installer release or a different kernel argument, because the platform handling for the Orin isn’t in the driver package yet.
On your two other questions:
Running these cameras on the AGX Orin Dev Kit in general: not possible right now.
Connecting both cameras at the same time into the camera connector: also not something I can confirm on the Orin, since the platform support isn’t there. On the supported Nano/NX boards, each camera needs its own CSI connector and matching driver — but that’s moot until Orin support lands.
So the realistic answer for now is to wait for Orin compatibility. There’s no confirmed release date, and I don’t want to give you a number I can’t stand behind. Keep an eye on the GitHub releases page — when an Orin-compatible package shows up, the installer will stop reporting UNKNOWN and this same flow should work.
If you’d like, reply back here with your L4T version when you next check, and we can re-test once there’s news.
