Arducam B0272 IMX477 camera not detected on Raspberry Pi 4 – libcamera: no cameras available
Hi all, hoping someone can point me in the right direction. I’ve got an Arducam B0272 (IMX477 Motorized Focus Camera) that my Raspberry Pi 4 Model B 8GB just won’t see at all. I’ve followed both the video guide and the Arducam docs quick start, the ribbon cable is seated properly as far as I can tell, and I’ve tested Raspberry Pi OS Bullseye 32-bit and Bookworm 64-bit. No camera shows up in any of them. Any ideas what I should check next?
Could you post some close-up photos of the physical connections and run the diagnostic bug report tool so we can see what the Pi is seeing? Reboot first, then run:
That should create arducam-bug-report.txt in the current directory. Attach that file here along with the connection photos.
Thanks. I ran the tool and it says no cameras are available. Here are the details:
Problem: camera never detected
Product: Arducam B0272 (IMX477 Motorized Focus Camera)
Host: atsq@pi4hqcamera
Pi: Raspberry Pi 4 Model B (8GB)
OS tried: Bullseye 32-bit and Bookworm 64-bit
Cable: pins facing the HDMI ports on the Pi side, pins facing the PCB on the camera side
Commands I ran:
Output:
arducam-camera-bug-report saved [5383/5383] (5.26K)
[0:05:06.548129955] [1503] INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
Bug report generated to arducam-bug-report.txt
I attached the two error log files (one renamed to .txt but otherwise unchanged) and close-up photos of the connections. I’ve re-seated the ribbon cable countless times and followed these guides:
Looking at your setup, the config.txt settings are correct so don’t change those. The most likely culprit is the cable orientation to the camera itself - it may be flipped over to the wrong side. Try disconnecting the cable, flipping it over, and reconnecting it. Keep config.txt exactly as it is.
I flipped the cable over and it still isn’t detected. vcgencmd get_camera gives:
atsq@pi4hqcamera:~ $ vcgencmd get_camera
supported=1 detected=0, libcamera interfaces=1
The connection still doesn’t look right to me, and the cable seems inserted as far as it will go. As a sanity check I also tested a regular Pi HQ camera (another IMX477) on the same Pi, and that one gets detected and works within minutes, so the Pi and the camera connector are fine. It’s definitely something with the Arducam unit or its cable.
That vcgencmd output means the camera interface is enabled but no camera is being detected (supported=1 detected=0). Since the Pi HQ camera works on the same connector, we’re narrowing this down to the Arducam cable or connection. Please keep the cable connected the way it is now and run the bug report script again so we can compare. Attach the new arducam-bug-report.txt.
I switched over to 64-bit Bookworm and re-ran the bug report script. Just sent over the new error reports. Still no detection on my end.
Thanks. Based on the new reports and everything we’ve tried so far, I’m suspecting the 15-22 pin yellow cable itself is faulty. If you have a spare 15-22 pin yellow cable available, swap it in and give it another shot. That’s the next thing to rule out.
