Arducam B0267 quad camera software installation failing on Forecr Jetson Orin NX
Hey everyone, I’m having trouble getting the Arducam quad camera kit (B0267) running on my Jetson Orin NX setup. The carrier board is from Forecr.
The software installation seems to fail — I can’t get any of the four cameras detected. I’m starting to suspect the Forecr board just isn’t supported by the Arducam drivers.
Here’s the weird part: I took the exact same camera setup and tested it on a Holybro carrier board with a Jetson Orin Nano, and everything worked perfectly out of the box. So the cameras themselves are fine.
Has anyone successfully used Arducam cameras with a Forecr carrier board on Orin NX? Is there a specific install procedure I’m missing, or is this a known incompatibility?
Thanks for the detailed report. The fact that the cameras work on the Holybro + Orin Nano combo is a good data point — it confirms the hardware isn’t faulty.
To help narrow this down, could you share a bit more about your Forecr setup? Specifically:
  • Which JetPack version are you running on the Orin NX?
  • What does dmesg | grep -i cam or dmesg | grep -i arducam show after boot?
  • Are you using the standard Arducam driver installation script, and if so, where exactly does it fail?
In the meantime, if you have access to an official NVIDIA Jetson Orin Developer Kit, that would be a useful baseline test. The drivers are validated primarily against the official carrier board, so it would help rule out whether this is specific to the Forecr board.
I’m running JetPack 5.1.2 on the Forecr Orin NX board. When I run the Arducam install script, it seems to complete but ls /dev/video* doesn’t show any of the expected camera devices afterwards.
dmesg output doesn’t show anything Arducam-related — no driver binding messages, no errors, nothing. It’s like the driver isn’t even attempting to probe the hardware.
On the Holybro + Orin Nano (also JetPack 5.1.2), the same script runs and I immediately get /dev/video0 through /dev/video7 showing up. Night and day difference.
Unfortunately I don’t have the official NVIDIA dev kit on hand, just these two carrier boards. Is there any way to force the driver to recognize the Forecr board’s CSI interface, or does the driver have a hard-coded board check that’s failing?
That dmesg silence is telling. On the official NVIDIA carrier board (and compatible third-party ones like Holybro), the camera driver registers against specific device tree entries and I2C bus layouts that the carrier board exposes. If the Forecr board has a different device tree configuration — different I2C addresses, different CSI lane mapping, or different GPIO pin assignments for camera reset/power — the driver simply won’t find anything to bind to. Hence no /dev/video nodes and nothing in the kernel log.
To answer your question directly: this isn’t just a software configuration issue. The Arducam camera driver is designed and validated for the NVIDIA Jetson Orin Developer Kit’s carrier board layout. The Forecr board is a third-party design, and unfortunately it appears the hardware-level CSI and I2C routing isn’t compatible with how the Arducam driver expects the cameras to be wired up.
Just to be thorough — could you share the output of:
sudo i2cdetect -y -r <bus_number>
for each I2C bus on the Forecr board? That would confirm whether the cameras are even visible on the I2C side.
Thanks for the explanation, that makes sense. I ran i2cdetect across all buses on the Forecr board and I’m not seeing any of the camera sensor addresses — the I2C buses that would normally have the Arducam sensors showing up are either empty or don’t exist.
On the Holybro board, the sensors show up clearly at the expected addresses.
So just to be crystal clear before I go down another path — is the Forecr Jetson Orin NX board fundamentally incompatible with the Arducam B0267 cameras? Or is there still a chance this could be resolved through some device tree hacking or a different driver configuration?
I’m trying to figure out if I should invest time trying to patch the device tree myself or if I should just move to a different carrier board.
I appreciate you checking the I2C buses — that confirms what we suspected. The fact that the sensors don’t appear on any I2C bus on the Forecr board means it’s not a driver configuration problem; the cameras are electrically invisible to the system at the hardware interface level.
To give you a definitive answer: the Forecr Jetson Orin NX carrier board is incompatible with the Arducam B0267 quad cameras. This is a hardware-level limitation, not something fixable through software installation or device tree modifications. The CSI connector pinouts, I2C routing, and/or power delivery on the Forecr board simply don’t match what the Arducam cameras require.
The Arducam camera driver stack is designed and validated specifically for the NVIDIA Jetson Orin Developer Kit’s carrier board (and certain third-party boards like Holybro that follow the same CSI/I2C layout). The Forecr board uses a different design that falls outside this compatibility envelope.
Your options at this point:
  • Switch to the official NVIDIA Jetson Orin Developer Kit (strongly recommended if you want a guaranteed-working setup)
  • Stick with the Holybro carrier board (since you’ve already confirmed it works with the cameras)
  • Look for another third-party carrier board that explicitly states Arducam compatibility or follows the NVIDIA reference CSI design closely
Unfortunately there’s no software or driver workaround I can offer for the Forecr board. The hardware just isn’t wired up in a way the driver can see the cameras.
