Hey everyone, I’m hitting a wall trying to get my Arducam B0223 camera working on a Jetson Xavier NX Developer Kit. I’m running the Jetvariety driver installation script and it keeps failing with this:
Kernel version: 5.10.216-tegra-35.6.1-20250304015758
Jetson type: NVIDIA Jetson Xavier NX Developer Kit
Here’s what I’m on:
Kernel: 5.10.216-tegra-35.6.1-20250304015758
Board: NVIDIA Jetson Xavier NX Developer Kit
Camera: Arducam B0223
Anyone know if there’s a compatible driver package for this kernel version? The script just can’t seem to find one.
Thanks for sharing the full error output. Looking at your kernel version — 5.10.216-tegra-35.6.1 — this maps to a JetPack 5.x release. The Jetvariety script works by matching pre-built deb packages against your kernel version and Jetson model, and it seems we don’t have a package built for this particular kernel/JetPack combination yet.
Just to double-check — can you confirm this is a Jetson Xavier NX and not an Orin NX? The kernel string is consistent with both and I want to make sure we’re looking at the right board before digging further.
Thanks for the photos — that helps a lot. So I can confirm that’s a Xavier NX module, but I also notice you’re using a third-party carrier board, not the official NVIDIA developer kit carrier.
Before we go further down the driver compatibility rabbit hole, I’d recommend testing the camera on the official NVIDIA Jetson Xavier NX Developer Kit carrier board if you have access to one. Third-party carrier boards can introduce all sorts of hardware-level issues — CSI lane routing differences, power delivery quirks, I2C address conflicts — that can make the camera fail even with the correct driver. We need to rule that out first.
Fair point. I went ahead and picked up an official NVIDIA Jetson Xavier NX Developer Kit (the 16GB RAM variant) to rule out the carrier board.
Just finished flashing it and ran the Jetvariety script again. Unfortunately, same exact error:
Here’s the official devkit:
So it’s definitely not a third-party hardware issue. I’m starting to think there simply isn’t a driver package built for this kernel version. Is the latest JetPack 5 not supported yet?
Okay, that confirms it — the third-party carrier board was a red herring. The root cause is exactly what you suspected: there is no pre-built Arducam driver deb package matching your specific JetPack version and kernel build.
The kernel 5.10.216-tegra-35.6.1-20250304015758 is a very recent JetPack 5.x point release, and the Jetvariety script simply doesn’t have a corresponding package for it yet.
After flashing a supported JetPack version, re-run the Jetvariety driver installation script — it should then find the matching deb package and proceed normally.
Essentially you’re just on a kernel build that’s ahead of what the driver packages currently cover. Rolling back to a supported JetPack release will get things working.
