We have 3 B0201 cams that give different results for white balance. When 1 camera needs WB temp setting of 4600 another needs 6400 to get the same result. Also, setting the exposure manually leads to very different results even with the same camera. When a setting of 50 gives a good picture, after a while we have to adjust it to 150 to get the same result. Otherwise the picture is almost black. Sometimes it helps to switch to automatic exposure and back to manual to get a good picture again, sometimes the only way is to disconnect and connect the USB again to restore the correct exposure. This happens with all three cameras. We are using the cameras on Ubuntu 18.04 and 20.04.
Any idea why we get totally different results from day to day with exactly the same manual settings?
