Hi, I need to correct an earlier report I made about this because I think I described it wrong. The real problem is that changing either the serial number OR the device name makes the cameras stop working properly once they’re re-plugged. I’m using Arducam B0200 cameras (ordered back in February).
What happens: I run the UVC serial number program and it pops up an error saying “unknown device”. The UVC serial tool doesn’t seem to be working right at all - when I change the name of the camera and follow the webpage instructions, the name doesn’t change in Device Manager even after uninstalling and re-plugging the camera. Also the green bar never fills up after completion in the UVC serial tool. After I change the name, the camera shows video in grayscale. And it’s only after reinstalling or replugging that the camera stops working correctly. The software we use can’t identify the webcams by serial number, which is the whole reason I’m trying to set these.
Environment: Windows 10 Device Manager, amcap.exe, OBS, the built-in Windows 10 camera app, usbview.exe, the UVC serial number tool, the firmware tool.
What I’ve tried so far:
Used usbview.exe to check the port the camera is attached to. I’ve attached 3 logs as .txt files: (1) right after a fresh firmware install and camera re-plug, (2) after changing the serial number to 001 but before re-plug, (3) after changing the serial number to 001 and after re-plug.
Ran the firmware tool on the cameras - it works fine.
Used the firmware tool to reset the cameras, and that works. It renames them back to arducam and the video shows in color again.
Tried changing the USB name to just “001” - same problem as before.
Interesting thing: after changing the name but BEFORE uninstalling/replugging, it seems to work normally in amcap.exe, but the USB name is still ‘Arducam USB Camera’.
Tried all four cameras on two different PCs, disconnecting everything but the camera, and on different USB ports - still same error.
Confirmed I quit amcap.exe before running the serial number program. amcap.exe is able to use the camera just fine after the unknown device error.
One of the four cameras is different from the others (it was sent to me because of low stock at the time).
Thanks for the detailed write-up and the correction, that actually helps a lot. A few things stand out already:
The firmware tool itself works fine for you (reset/rename back to arducam works and video returns to color), so the flashing path via USB is OK.
The UVC serial tool throwing “unknown device” and the green progress bar never completing suggests the tool isn’t finding/matching the camera during the write step.
The name not updating in Device Manager, then grayscale video, then failure after a replug - that sequence is important.
Can you confirm a couple of things for me?
Which exact version/build of the UVC serial tool are you running?
In Device Manager, under Cameras (and under USB devices), what does the camera show up as right now, before you change anything?
Have you tried running the serial tool as Administrator?
Also, if you can re-post the three usbview logs as plain text in the thread (or note which one is which), I’d like to look at the descriptors before and after the serial change - that’s usually where this kind of thing shows up.
Just a follow-up - still no success getting the cameras to work with the serial number. They’re still not working properly after a replug. Has there been any progress on your end?
Everything I’ve tried is on my side - no luck, so I’m waiting on you guys.
Thanks for checking in, and sorry for the slow loop on this. I haven’t forgotten it.
Can I get you to reconfirm the exact behavior right now, so I know nothing has drifted: when you flash the firmware (no name change) and replug, does the camera come back in color and work in amcap.exe every time? If yes, that tells us the issue is specifically tied to the write step of the name/serial and not the hardware.
Also, please try running the UVC serial tool as Administrator and let me know if the “unknown device” error changes at all.
Yes, we have been testing on this and I have an update for you - but first I need to check something on the delivery side.
We tested a new software build for this and it worked normally in our testing.
I actually sent you an email back on 2022.6.21 that contained (or related to) this new software, but I don’t think you’ve confirmed receiving it. Can you please confirm whether you got that mail? If you didn’t receive it, I’ll send it again.
The reason I’m asking is that this might just be an email delivery problem, because the new software we tested is exactly what should address the name/serial writing issue you’re hitting.
No, I haven’t received any email - definitely don’t have anything from that date. Could you send it through again? I’m keen to test it as soon as I can get it.
Thanks for confirming. Since email clearly isn’t getting through, I’ve sent the new software package to you through private message instead - please check your messages and download the attached files there.
Here’s how to use it. This new software is what we developed specifically to modify the camera device name, and it should address both the name/serial not writing and the “unknown device” / green-bar-never-completing problems you had with the UVC serial tool.
First, download all the attached files and place them all in a single folder.
Make sure there is an src file in the package.
After plugging the camera in, open the app and first check whether the src file can be detected.
Read the camera information.
Modify the device name. Important note here: please set the name as long as possible. In our testing, modifying just “001” could not be written - the tool needs a longer name to write successfully.
Choose the src file and start burning the firmware.
After burning the firmware, you need to uninstall the device and replug the camera, then check whether it works in Device Manager.
One thing worth calling out on the root cause side: the character-length limitation is the key - very short names like “001” wouldn’t write in our tests, which lines up with the exact case you tried. Please set the name as long as you reasonably can and let me know what you see in Device Manager after the uninstall/replug.
