Arducam AR0234 stereo camera kit intermittent, only one CSI port works on Jetson Orin Nano
Hi everyone, I’m testing the Arducam 2.3MP*2 AR0234 Color Global Shutter Synchronized Stereo Camera Bundle Kit on a Jetson Orin Nano. The camera bundle only seems to work on one of the CSI ports — the cam0 port never comes up. On top of that, it’s intermittent and unstable even on the working port. Has anyone else run into this? Is the cam0 port just not usable on Orin?
Hi, thanks for the details. This is actually a known limitation on the Orin series — the V4L2 cam0 port can’t be used for these camera modules. NVIDIA has an open thread about it here: Orin series v4l2 cam0 port cannot be used - Jetson Orin Nano - NVIDIA Developer Forums. From what we’ve seen, there’s no good solution for the cam0 port at the moment.
Thanks for the link. For more background — I’m on JetPack 5 and followed the Arducam instructions from the official site. My end goal is to connect 8 of these cameras to a Jetson Nano for development, and I was hoping to run two of these stereo bundles on one Orin Nano. Is there any workaround, like using a different cam port or a USB converter? Also, does this cam0 issue happen on JetPack 4 or JetPack 6 as well, and on other Jetson boards?
Good questions. Unfortunately, if cam0 doesn’t work, there’s no workaround to run two of these synchronized stereo kits on the same Orin Nano. There are no other usable cam ports for this module, and a USB converter isn’t an option either. The issue also isn’t tied to the JetPack version — JetPack 4, 5, and 6 all behave the same — and it affects the Orin NX board too, not just the Orin Nano.
Since you mentioned you need 8 cameras, you might want to look at these synchronized multi-camera kits instead, which scale differently than the AR0234 stereo kit:
  1. Arducam 1MP*4 Quadrascopic Camera Bundle Kit (IMX219): Arducam 1MP*4 Quadrascopic Camera Bundle Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Four IMX219 Color Camera Modules and Camarray Camera HAT
  2. Arducam 12MP*4 IMX477 Quadrascopic Camera Bundle Kit: Arducam 12MP*4 Quadrascopic Camera Bundle Kit for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Four IMX477 Color Camera Modules and Camarray Camera HAT
  3. 16MP Synchronized Quad Camera Kit: 16MP Synchronized Quad-Camera Kit
Okay, that’s disappointing but thanks for confirming. One last thing — is the cam0 problem a software/driver issue or a hardware issue? If it’s a driver problem, is there any chance it gets fixed in a future release? I’d like to understand the root cause before I decide whether to switch hardware.
From what we’ve seen, it’s a board/hardware limitation on the Orin series rather than something fixable in a driver or JetPack update — that’s why JetPack 4/5/6 all behave the same. The cam0 V4L2 port simply isn’t usable for these modules on the Orin Nano or Orin NX. To summarize: the AR0234 stereo kit will only run on the one working CSI port, and running two of these kits on a single Orin Nano/NX isn’t possible. For an 8-camera setup, the alternative synchronized kits I listed above are the better route.
