hi…
i bought this :
can’t get it working… can someone help me?
the Error :
libcamera-hello: symbol lookup error: /usr/local/lib/arm-linux-gnueabihf/libcamera/ipa_rpi.so: undefined symbol: _ZN9libcamera14FileDescriptorC1ERKi
i use ipa_rpi.so v0.0.3 from :
https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/ipa-v0.0.3/ipa_rpi.tar.xz
complete log :
[email protected]:~ $ uname -a
Linux raspberrypi 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l GNU/Linux
[email protected]:~ $ libcamera-hello --version
libcamera-apps build: 015efd0e17cb-intree 17-04-2022 (05:19:36)
libcamera build: v0.0.0+3517-dd8b1723
[email protected]:~ $ dmesg | grep arducam
[ 8.805325] arducam: loading out-of-tree module taints kernel.
[ 8.955251] arducam-pivariety 10-000c: firmware version: 0x10003
[ 9.560589] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
[email protected]:~ $ ls /dev/video* -l
crw-rw----+ 1 root video 81, 13 Apr 17 04:54 /dev/video0
crw-rw----+ 1 root video 81, 14 Apr 17 04:54 /dev/video1
crw-rw----+ 1 root video 81, 4 Apr 17 04:54 /dev/video10
crw-rw----+ 1 root video 81, 5 Apr 17 04:54 /dev/video11
crw-rw----+ 1 root video 81, 10 Apr 17 04:54 /dev/video12
crw-rw----+ 1 root video 81, 0 Apr 17 04:54 /dev/video13
crw-rw----+ 1 root video 81, 1 Apr 17 04:54 /dev/video14
crw-rw----+ 1 root video 81, 2 Apr 17 04:54 /dev/video15
crw-rw----+ 1 root video 81, 3 Apr 17 04:54 /dev/video16
crw-rw----+ 1 root video 81, 11 Apr 17 04:54 /dev/video18
crw-rw----+ 1 root video 81, 6 Apr 17 04:54 /dev/video20
crw-rw----+ 1 root video 81, 7 Apr 17 04:54 /dev/video21
crw-rw----+ 1 root video 81, 8 Apr 17 04:54 /dev/video22
crw-rw----+ 1 root video 81, 9 Apr 17 04:54 /dev/video23
crw-rw----+ 1 root video 81, 12 Apr 17 04:54 /dev/video31
[email protected]:~ $ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Stepwise 16x16 - 16376x16376 with step 1/1
[1]: 'UYVY' (UYVY 4:2:2)
[2]: 'YVYU' (YVYU 4:2:2)
[3]: 'VYUY' (VYUY 4:2:2)
[4]: 'RGBP' (16-bit RGB 5-6-5)
[5]: 'RGBR' (16-bit RGB 5-6-5 BE)
[6]: 'RGBO' (16-bit A/XRGB 1-5-5-5)
[7]: 'RGBQ' (16-bit A/XRGB 1-5-5-5 BE)
[8]: 'RGB3' (24-bit RGB 8-8-8)
[9]: 'BGR3' (24-bit BGR 8-8-8)
[10]: 'RGB4' (32-bit A/XRGB 8-8-8-8)
[11]: 'BA81' (8-bit Bayer BGBG/GRGR)
[12]: 'GBRG' (8-bit Bayer GBGB/RGRG)
[13]: 'GRBG' (8-bit Bayer GRGR/BGBG)
[14]: 'RGGB' (8-bit Bayer RGRG/GBGB)
[15]: 'pBAA' (10-bit Bayer BGBG/GRGR Packed)
[16]: 'BG10' (10-bit Bayer BGBG/GRGR)
[17]: 'pGAA' (10-bit Bayer GBGB/RGRG Packed)
[18]: 'GB10' (10-bit Bayer GBGB/RGRG)
[19]: 'pgAA' (10-bit Bayer GRGR/BGBG Packed)
[20]: 'BA10' (10-bit Bayer GRGR/BGBG)
[21]: 'pRAA' (10-bit Bayer RGRG/GBGB Packed)
[22]: 'RG10' (10-bit Bayer RGRG/GBGB)
[23]: 'pBCC' (12-bit Bayer BGBG/GRGR Packed)
[24]: 'BG12' (12-bit Bayer BGBG/GRGR)
[25]: 'pGCC' (12-bit Bayer GBGB/RGRG Packed)
[26]: 'GB12' (12-bit Bayer GBGB/RGRG)
[27]: 'pgCC' (12-bit Bayer GRGR/BGBG Packed)
[28]: 'BA12' (12-bit Bayer GRGR/BGBG)
[29]: 'pRCC' (12-bit Bayer RGRG/GBGB Packed)
[30]: 'RG12' (12-bit Bayer RGRG/GBGB)
[31]: 'pBEE' (14-bit Bayer BGBG/GRGR Packed)
[32]: 'BG14' (14-bit Bayer BGBG/GRGR)
[33]: 'pGEE' (14-bit Bayer GBGB/RGRG Packed)
[34]: 'GB14' (14-bit Bayer GBGB/RGRG)
[35]: 'pgEE' (14-bit Bayer GRGR/BGBG Packed)
[36]: 'GR14' (14-bit Bayer GRGR/BGBG)
[37]: 'pREE' (14-bit Bayer RGRG/GBGB Packed)
[38]: 'RG14' (14-bit Bayer RGRG/GBGB)
[39]: 'GREY' (8-bit Greyscale)
[40]: 'Y10P' (10-bit Greyscale (MIPI Packed))
[41]: 'Y10 ' (10-bit Greyscale)
[42]: 'Y12P' (12-bit Greyscale (MIPI Packed))
[43]: 'Y12 ' (12-bit Greyscale)
[44]: 'Y14P' (14-bit Greyscale (MIPI Packed))
[45]: 'Y14 ' (14-bit Greyscale)
Preview window unavailable
[0:29:15.771130361] [6704] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3517-dd8b1723
[0:29:15.805431131] [6705] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam-pivariety'
[0:29:15.805513630] [6705] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:29:15.805585648] [6705] ERROR CameraSensor camera_sensor.cpp:591 'arducam-pivariety 10-000c': Camera sensor does not support test pattern modes.
thanks
