Arducam 8MP Synchronized Stereo Camera Kit IMX219 not detected on CM4 MIPI RX2/RX3
Hi, I’m trying to get my Arducam cameras detected on a Raspberry Pi Compute Module 4 and I’m completely stuck. I have the Arducam 8MP Synchronized Stereo Camera Bundle Kit, with two IMX219 cameras connected to the MIPI RX2 and MIPI RX3 ports on the CM4. Neither camera shows up. I’ve already enabled the camera interface through raspi-config and turned on I2C in the settings, but it didn’t help.
Thanks for posting. Can you run these two and paste the output here?
libcamera-hello --list-cameras
i2cdetect
That will show us whether the kernel/driver side is even seeing the sensors, or if it’s more of a wiring/detection problem.
Here’s what I get:
libcamera-hello --list-cameras returns:
No cameras available
i2cdetect shows no devices detected at all.
For what it’s worth, I’ve double-checked the hardware connections, re-enabled the camera interface in raspi-config, and confirmed I2C is enabled. I’ve attached screenshots of my config.txt and the wiring so you can see the setup.
Thanks. Can you also check vcgencmd get_camera and run dmesg | grep -i camera? The list-cameras result plus those two will tell us whether the firmware/kernel is enumerating the IMX219 sensors at all.
Sure. vcgencmd get_camera gives:
supported=1 detected=0
And dmesg | grep -i camera doesn’t return anything relevant about the cameras being detected.
That output points to the root cause. The Arducam 8MP Synchronized Stereo Camera Bundle Kit’s HAT is designed to have all four IMX219 cameras populated. With only two cameras on the board (your RX2 and RX3), the CM4 won’t properly detect any of them - which matches detected=0 and the empty i2cdetect.
To fix it:
  1. Connect all four IMX219 cameras to the HAT board.
  2. Add this line to config.txt:
dtoverlay=imx219
  1. For dual-channel mode, follow the Arducam Multi-Camera Setup Guide:
    Quick Start Guide for Arducam CamArray HAT Kit - Arducam Wiki
All four cameras need to be populated on the HAT for the CM4 to detect them properly.
Thanks for the pointers. I’ve since moved the setup over to a Raspberry Pi 5 and now I’m hitting a different wall. sudo i2cdetect -y 4 now shows address 0x24 detected, so the camera is at least visible on I2C. But I can’t get past that to actually access the Arducam camera and capture images or video. I’ve tried various examples and solutions I found online and none of them worked with this setup. I’ve attached a screenshot of the I2C address output and a photo of the connection.
So on the Pi 5 you’ve confirmed the camera responds on I2C bus 4 at 0x24 - that part of the link is up. Getting from I2C detection to actual image/video capture is a separate step, though: it needs the camera driver/overlay to be loaded for the Pi 5, not just the I2C address showing up.
From what we covered on the CM4, the two things that mattered were having all four cameras populated on the HAT and dtoverlay=imx219 in config.txt. If capture still fails on the Pi 5, the equivalent driver/overlay config needs to be checked for that platform.
Current status of this thread: I2C detection confirmed (0x24 on bus 4), but image/video capture is still not working on the Pi 5 - no confirmed fix yet.
