I’ve tried every possible variation. Rpi4 4GB, Rpi4 8GB, 32bit, 64bit. CMA-512 … everything. New installs. All according to the instructions.
Unfortunately the camera still only saves 16Mpix photos even if I switch the mode to --mode 9152:6944
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 108.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2711
Revision : d03115
Serial : 10000000dba32931
Model : Raspberry Pi 4 Model B Rev 1.5
[email protected]:~/Desktop/Images $ cat /proc/meminfo
MemTotal: 8100288 kB
MemFree: 7068692 kB
MemAvailable: 7495004 kB
Buffers: 29900 kB
Cached: 545968 kB
SwapCached: 0 kB
Active: 140260 kB
Inactive: 748292 kB
Active(anon): 1608 kB
Inactive(anon): 251508 kB
Active(file): 138652 kB
Inactive(file): 496784 kB
Unevictable: 26588 kB
Mlocked: 1824 kB
HighTotal: 7471104 kB
HighFree: 6549032 kB
LowTotal: 629184 kB
LowFree: 519660 kB
SwapTotal: 524284 kB
SwapFree: 524284 kB
Dirty: 232 kB
Writeback: 0 kB
AnonPages: 339280 kB
Mapped: 186280 kB
Shmem: 34212 kB
KReclaimable: 24348 kB
Slab: 48524 kB
SReclaimable: 24348 kB
SUnreclaim: 24176 kB
KernelStack: 2480 kB
PageTables: 7096 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 4574428 kB
Committed_AS: 1548116 kB
VmallocTotal: 245760 kB
VmallocUsed: 6928 kB
VmallocChunk: 0 kB
Percpu: 496 kB
CmaTotal: 524288 kB
CmaFree: 499080 kB
[email protected]:~/Desktop/Images $ cat /etc/os-release
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
ls /dev/video*
/dev/video0 /dev/video1 /dev/video10 /dev/video11 /dev/video12 /dev/video13 /dev/video14 /dev/video15 /dev/video16 /dev/video18 /dev/video19 /dev/video20 /dev/video21 /dev/video22 /dev/video23 /dev/video31
[email protected]:~/Desktop/Images $ dpkg -l | grep libcamera
ii libcamera-apps 0.0.10 armhf libcamera-apps
ii libcamera-dev 0.0.10 armhf libcamera
[pi4]
arm_boost=1
dtoverlay=w1-gpio
dtoverlay=vc4-kms-v3d,cma-512
dtoverlay=arducam_64mp
dtoverlay=arducam_64mp, cam0
dtparam=watchdog=on
gpu_mem=64
[email protected]:~/Desktop/Images $ libcamera-still -t 1000 -n
[0:17:29.941623636] [1948] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3897-c3c878a9
[0:17:29.998245122] [1950] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for 'arducam_64mp'
[0:17:29.998291918] [1950] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:17:30.017508330] [1950] WARN RPI raspberrypi.cpp:1280 Mismatch between Unicam and CamHelper for embedded data usage!
[0:17:30.018389841] [1950] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:17:30.018558692] [1950] INFO RPI raspberrypi.cpp:1404 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media2 and ISP device /dev/media0
[0:17:30.019169538] [1948] INFO Camera camera.cpp:1035 configuring streams: (0) 4624x3472-YUV420
[0:17:30.019583979] [1950] INFO RPI raspberrypi.cpp:765 Sensor: /base/soc/i2c0mux/[email protected]/[email protected] - Selected sensor format: 4624x3472-SBGGR10_1X10 - Selected unicam format: 4624x3472-pBAA
[email protected]:~/Desktop/Images $ sudo dmesg
[ 0.000000] Linux version 5.15.76-v7l+ ([email protected]) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1597 SMP Fri Nov 4 12:14:58 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Reserved memory: bypass linux,cma node, using cmdline CMA params instead
[ 0.000000] OF: reserved mem: node linux,cma compatible matching fail
[ 0.000000] cma: Reserved 512 MiB at 0x000000000ec00000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003bffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[ 0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2062656
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:95:D0:A4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=ae7af0fa-02 rootfstype=ext4 fsck.repair=yes rootwait splash plymouth.ignore-serial-consoles coherent_pool=6M smsc95xx.turbo_mode=N cma=512M
[ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[ 0.000000] software IO TLB: mapped [mem 0x0000000006400000-0x000000000a400000] (64MB)
[ 0.000000] Memory: 7573952K/8257536K available (10240K kernel code, 1386K rwdata, 3308K rodata, 2048K init, 591K bss, 159296K reserved, 524288K cma-reserved, 7471104K highmem)
[ 0.001391] LSM: Security Framework initializing
[ 0.001604] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001653] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003198] cgroup: Disabling memory control group subsystem
[ 0.003451] CPU: Testing write buffer coherency: ok
[ 0.003521] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[ 0.003978] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005505] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005726] rcu: Hierarchical SRCU implementation.
[ 0.006755] smp: Bringing up secondary CPUs ...
[ 0.007950] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009275] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010640] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010801] smp: Brought up 1 node, 4 CPUs
[ 0.010883] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010914] CPU: All CPU(s) started in HYP mode.
[ 0.010940] CPU: Virtualization extensions available.
[ 0.011712] devtmpfs: initialized
[ 0.027489] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.027735] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.027792] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.043385] pinctrl core: initialized pinctrl subsystem
[ 0.044658] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.053139] DMA: preallocated 6144 KiB pool for atomic coherent allocations
[ 0.053969] audit: initializing netlink subsys (disabled)
[ 0.054242] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[ 0.054876] thermal_sys: Registered thermal governor 'step_wise'
[ 0.055737] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.055795] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.056206] Serial: AMBA PL011 UART driver
[ 0.072449] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.120097] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-10-26T11:09:05, variant start
[ 0.130114] raspberrypi-firmware soc:firmware: Firmware hash is c72ad6b26ff40c91ef776b847436094ee63fabee
[ 0.190236] Kprobes globally optimized
[ 0.196324] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.201267] vgaarb: loaded
[ 0.201759] SCSI subsystem initialized
[ 0.202004] usbcore: registered new interface driver usbfs
[ 0.202079] usbcore: registered new interface driver hub
[ 0.202167] usbcore: registered new device driver usb
[ 0.202615] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.202812] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.203145] pps_core: LinuxPPS API ver. 1 registered
[ 0.203175] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.203223] PTP clock support registered
[ 0.205009] clocksource: Switched to clocksource arch_sys_counter
[ 0.285744] VFS: Disk quotas dquot_6.6.0
[ 0.285875] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.286073] FS-Cache: Loaded
[ 0.286268] CacheFiles: Loaded
[ 0.295434] NET: Registered PF_INET protocol family
[ 0.295705] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.297324] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.297382] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.297428] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.297512] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.297599] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.297771] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.297828] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.298099] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.299122] RPC: Registered named UNIX socket transport module.
[ 0.299157] RPC: Registered udp transport module.
[ 0.299185] RPC: Registered tcp transport module.
[ 0.299211] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.299247] PCI: CLS 0 bytes, default 64
[ 1.353630] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.356341] Initialise system trusted keyrings
[ 1.356648] workingset: timestamp_bits=14 max_order=21 bucket_order=7
[ 1.365727] zbud: loaded
[ 1.367685] FS-Cache: Netfs 'nfs' registered for caching
[ 1.368595] NFS: Registering the id_resolver key type
[ 1.368647] Key type id_resolver registered
[ 1.368675] Key type id_legacy registered
[ 1.368837] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.368869] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.369984] Key type asymmetric registered
[ 1.370016] Asymmetric key parser 'x509' registered
[ 1.370258] bounce: pool size: 64 pages
[ 1.370335] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.370593] io scheduler mq-deadline registered
[ 1.370625] io scheduler kyber registered
[ 1.380488] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
[ 1.380555] brcm-pcie fd500000.pcie: No bus range found for /scb/[email protected], using [bus 00-ff]
[ 1.380670] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.380782] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x01ffffffff -> 0x0400000000
[ 1.437112] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.437518] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.437555] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.437591] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.437704] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.437978] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.441822] PCI: bus0: Fast back to back transfers disabled
[ 1.441863] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.442258] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.442403] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.442850] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.446700] PCI: bus1: Fast back to back transfers disabled
[ 1.446737] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.446796] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.446838] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.446942] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.446981] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.447423] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.447674] pcieport 0000:00:00.0: PME: Signaling with IRQ 80
[ 1.461763] iproc-rng200 fe104000.rng: hwrng registered
[ 1.462171] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.463792] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.476587] brd: module loaded
[ 1.486823] loop: module loaded
[ 1.487610] Loading iSCSI transport class v2.0-870.
[ 1.492903] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.585170] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.586391] usbcore: registered new interface driver r8152
[ 1.586478] usbcore: registered new interface driver lan78xx
[ 1.586556] usbcore: registered new interface driver smsc95xx
[ 1.634295] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.634348] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.640978] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000740000000890
[ 1.642076] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.642118] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.642163] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.642572] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.642616] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.642653] usb usb1: Product: xHCI Host Controller
[ 1.642683] usb usb1: Manufacturer: Linux 5.15.76-v7l+ xhci-hcd
[ 1.642714] usb usb1: SerialNumber: 0000:01:00.0
[ 1.643449] hub 1-0:1.0: USB hub found
[ 1.643533] hub 1-0:1.0: 1 port detected
[ 1.644568] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.644612] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.644649] usb usb2: Product: xHCI Host Controller
[ 1.644679] usb usb2: Manufacturer: Linux 5.15.76-v7l+ xhci-hcd
[ 1.644709] usb usb2: SerialNumber: 0000:01:00.0
[ 1.645466] hub 2-0:1.0: USB hub found
[ 1.645579] hub 2-0:1.0: 4 ports detected
[ 1.647543] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.647947] dwc_otg: FIQ enabled
[ 1.647961] dwc_otg: NAK holdoff enabled
[ 1.647975] dwc_otg: FIQ split-transaction FSM enabled
[ 1.647992] Module dwc_common_port init
[ 1.648432] usbcore: registered new interface driver uas
[ 1.648558] usbcore: registered new interface driver usb-storage
[ 1.648795] mousedev: PS/2 mouse device common for all mice
[ 1.654666] sdhci: Secure Digital Host Controller Interface driver
[ 1.654704] sdhci: Copyright(c) Pierre Ossman
[ 1.655534] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.659443] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.659788] hid: raw HID events driver (C) Jiri Kosina
[ 1.659999] usbcore: registered new interface driver usbhid
[ 1.660029] usbhid: USB HID core driver
[ 1.666108] Initializing XFRM netlink socket
[ 1.666173] NET: Registered PF_PACKET protocol family
[ 1.666307] Key type dns_resolver registered
[ 1.666857] Registering SWP/SWPB emulation handler
[ 1.667692] registered taskstats version 1
[ 1.667736] Loading compiled-in X.509 certificates
[ 1.668590] Key type ._fscrypt registered
[ 1.668621] Key type .fscrypt registered
[ 1.668648] Key type fscrypt-provisioning registered
[ 1.681152] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.681521] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.681674] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 1.691161] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.691673] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.692982] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.693020] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.721285] of_cfs_init
[ 1.721532] of_cfs_init: OK
[ 1.757971] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.758388] Waiting for root device PARTUUID=ae7af0fa-02...
[ 1.812200] mmc1: new high speed SDIO card at address 0001
[ 1.827144] mmc0: new DDR MMC card at address 0001
[ 1.828157] mmcblk0: mmc0:0001 BJTD4R 29.1 GiB
[ 1.831282] mmcblk0: p1 p2
[ 1.831829] mmcblk0: mmc0:0001 BJTD4R 29.1 GiB
[ 1.832362] mmcblk0boot0: mmc0:0001 BJTD4R 4.00 MiB
[ 1.834858] mmcblk0boot1: mmc0:0001 BJTD4R 4.00 MiB
[ 1.837128] mmcblk0rpmb: mmc0:0001 BJTD4R 4.00 MiB, chardev (242:0)
[ 1.857426] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.857539] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.858186] devtmpfs: mounted
[ 1.869278] Freeing unused kernel image (initmem) memory: 2048K
[ 1.896234] Run /sbin/init as init process
[ 1.896265] with arguments:
[ 1.896278] /sbin/init
[ 1.896291] splash
[ 1.896304] with environment:
[ 1.896317] HOME=/
[ 1.896329] TERM=linux
[ 1.925121] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.107717] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.107781] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.107818] usb 1-1: Product: USB2.0 Hub
[ 2.110127] hub 1-1:1.0: USB hub found
[ 2.110469] hub 1-1:1.0: 4 ports detected
[ 2.212145] systemd[1]: System time before build time, advancing clock.
[ 2.401241] NET: Registered PF_INET6 protocol family
[ 2.402925] Segment Routing with IPv6
[ 2.402987] In-situ OAM (IOAM) with IPv6
[ 2.474617] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.475677] systemd[1]: Detected architecture arm.
[ 2.485953] systemd[1]: Set hostname to <raspberrypiCAM>.
[ 3.238220] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.467713] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.473178] systemd[1]: Created slice system-getty.slice.
[ 3.474920] systemd[1]: Created slice system-modprobe.slice.
[ 3.476391] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.477712] systemd[1]: Created slice system-wg\x2dquick.slice.
[ 3.478862] systemd[1]: Created slice User and Session Slice.
[ 3.479690] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.481240] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.482234] systemd[1]: Reached target Host and Network Name Lookups.
[ 3.482757] systemd[1]: Reached target Slices.
[ 3.483246] systemd[1]: Reached target Swap.
[ 3.484742] systemd[1]: Listening on Syslog Socket.
[ 3.486199] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.486948] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.488375] systemd[1]: Listening on Journal Audit Socket.
[ 3.489509] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.490790] systemd[1]: Listening on Journal Socket.
[ 3.492174] systemd[1]: Listening on udev Control Socket.
[ 3.493285] systemd[1]: Listening on udev Kernel Socket.
[ 3.494524] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.500198] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.507221] systemd[1]: Mounting RPC Pipe File System...
[ 3.514853] systemd[1]: Mounting Kernel Debug File System...
[ 3.523514] systemd[1]: Mounting Kernel Trace File System...
[ 3.524781] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.533874] systemd[1]: Starting Restore / save the current clock...
[ 3.543472] systemd[1]: Starting Set the console keyboard layout...
[ 3.551364] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 3.559470] systemd[1]: Starting Load Kernel Module configfs...
[ 3.568407] systemd[1]: Starting Load Kernel Module drm...
[ 3.577187] systemd[1]: Starting Load Kernel Module fuse...
[ 3.582343] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.589679] systemd[1]: Starting File System Check on Root Device...
[ 3.603515] systemd[1]: Starting Journal Service...
[ 3.617517] systemd[1]: Starting Load Kernel Modules...
[ 3.625560] systemd[1]: Starting Coldplug All udev Devices...
[ 3.652739] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.670636] systemd[1]: Mounted RPC Pipe File System.
[ 3.684078] systemd[1]: Mounted Kernel Debug File System.
[ 3.685161] systemd[1]: Mounted Kernel Trace File System.
[ 3.687441] systemd[1]: Finished Restore / save the current clock.
[ 3.690658] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.693799] systemd[1]: [email protected]: Succeeded.
[ 3.695279] systemd[1]: Finished Load Kernel Module configfs.
[ 3.707135] systemd[1]: Mounting Kernel Configuration File System...
[ 3.714312] systemd[1]: Started File System Check Daemon to report status.
[ 3.730959] fuse: init (API version 7.34)
[ 3.743026] i2c_dev: i2c /dev entries driver
[ 3.760759] systemd[1]: [email protected]: Succeeded.
[ 3.762254] systemd[1]: Finished Load Kernel Module fuse.
[ 3.764657] systemd[1]: Finished Load Kernel Modules.
[ 3.806028] systemd[1]: Mounted Kernel Configuration File System.
[ 3.815740] systemd[1]: Mounting FUSE Control File System...
[ 3.823223] systemd[1]: Starting Apply Kernel Variables...
[ 3.879466] systemd[1]: Mounted FUSE Control File System.
[ 3.906525] systemd[1]: [email protected]: Succeeded.
[ 3.908136] systemd[1]: Finished Load Kernel Module drm.
[ 3.920198] systemd[1]: Finished Apply Kernel Variables.
[ 3.952025] systemd[1]: Finished File System Check on Root Device.
[ 3.958054] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.037566] systemd[1]: Started Journal Service.
[ 4.135083] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 4.200732] systemd-journald[137]: Received client request to flush runtime journal.
[ 4.209023] systemd-journald[137]: File /var/log/journal/cd988f5bf047451d9793a38fb75096ea/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.235738] Driver for 1-wire Dallas network protocol.
[ 5.251073] gpio-4 ([email protected]): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 5.292990] mc: Linux media interface: v0.10
[ 5.419140] videodev: Linux video capture interface: v2.00
[ 5.511318] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.513662] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.513691] [vc_sm_connected_init]: start
[ 5.528971] [vc_sm_connected_init]: installed successfully
[ 5.543883] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.572204] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.599336] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.654720] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.698701] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.699563] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 5.747580] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.805760] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.820941] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.823704] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.826994] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.859085] i2c i2c-22: Added multiplexed i2c bus 0
[ 5.861750] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[ 5.866048] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.866085] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.866111] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.866134] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.866156] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.882788] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 5.908152] i2c i2c-22: Added multiplexed i2c bus 10
[ 5.908716] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 5.909520] rpivid feb10000.codec: Device registered as /dev/video19
[ 5.924591] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 5.966569] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 5.966616] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.966655] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.966685] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.966711] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.967139] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.969104] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.969156] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.994834] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.994892] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.036826] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.036877] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.112454] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.112506] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.184248] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.184300] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 6.206820] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.608423] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.661361] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.674092] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 6.979930] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.009650] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.010763] usbcore: registered new interface driver brcmfmac
[ 7.017782] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.056838] Registered IR keymap rc-cec
[ 7.057053] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.057274] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 7.074197] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.076905] Registered IR keymap rc-cec
[ 7.077116] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.077357] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
[ 7.085836] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.086424] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.086865] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.087324] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.087742] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.088134] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.088571] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.092570] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.092929] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 7.316936] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.326506] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25
[ 9.798116] dw9807_vcm: loading out-of-tree module taints kernel.
[ 9.812141] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 9.821987] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
[ 17.115145] vc4-drm gpu: [drm] Cannot find any crtc or sizes
