Camera install and initializes properly.
dmesg | grep arducam checks out
ls /dev/video0 returns /dev/video0
dtoverlay=vc4-kms-v3d,cma-512 added to /boot/config.txt
libcamera-still -t 0 returns preview window with image
arducam_64mp 10-001a: Device found Arducam 64MP.
Troubleshooting attempts youâve made?
Updating the system, which breaks camera drivers. Camera stops working after updating the Pi OS???
I tried running simple py preview script:
#!/usr/bin/python3
Normally the QtGlPreview implementation is recommended as it benefits
from GPU hardware acceleration.
import time
picam2 = Picamera2()
picam2.start_preview(Preview.QTGL)
preview_config = picam2.create_preview_configuration()
picam2.start()
time.sleep(5)
I get this:
[0:12:43.535689593] [1872] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3730-67300b62
[0:12:43.541972436] [1873] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for âarducam_64mpâ
[0:12:43.542057676] [1873] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:12:43.569298653] [1873] WARN RPI raspberrypi.cpp:1274 Mismatch between Unicam and CamHelper for embedded data usage!
[0:12:43.569856240] [1873] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:12:43.570106478] [1873] INFO RPI raspberrypi.cpp:1398 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media1
Exception in thread Thread-1:
File â/usr/lib/python3.9/threading.pyâ, line 954, in _bootstrap_inner
self.run()
File â/usr/lib/python3.9/threading.pyâ, line 892, in run
self._target(*self._args, **self._kwargs)
File â/usr/local/lib/python3.9/dist-packages/picamera2/previews/qt_previews.pyâ, line 22, in thread_func
self.qpicamera2 = self.make_picamera2_widget(picam2, width=self.width, height=self.height, transform=self.transform)
File â/usr/local/lib/python3.9/dist-packages/picamera2/previews/qt_previews.pyâ, line 74, in make_picamera2_widget
from picamera2.previews.qt import QGlPicamera2
File â/usr/local/lib/python3.9/dist-packages/picamera2/previews/qt.pyâ, line 1, in
from .q_gl_picamera2 import EglState, QGlPicamera2
File â/usr/local/lib/python3.9/dist-packages/picamera2/previews/q_gl_picamera2.pyâ, line 13, in
import OpenGL
ModuleNotFoundError: No module named âOpenGLâ
Hi Edward,
thanks for pointing it out. I did fresh installs and got PiCamera2 working fully with Pi cameras v1 and v2. Upon installing the Arducam 64MP drivers, Iâve got the next error:
AttributeError: type object âlibcamera._libcamera.ColorSpaceâ has no attribute âSyccâ
Thanks for the info, this is very helpful, this is indeed the next phase of what we are going to do, until then, please lower the picamera2 version to use.
It is possible that the signal receiving the data is unstable.
Solution idea: swap the csi to the mipi port and try to reinsert it again.
ports A and B, and C and D. In each of these two groups, at least one camera needs to be good, although it is highly unlikely that there is a problem with any of the cameras in either group.
Solution. Try single channel
# Set to single channel 0
i2cset -y 10 0x24 0x24 0x02
# Set to single channel 1
i2cset -y 10 0x24 0x24 0x12
# Set to single channel 2
i2cset -y 10 0x24 0x24 0x22
# Set to single channel 3
i2cset -y 10 0x24 0x24 0x32
Switch one at a time and try libcamera-still -t 0 again to see if one channel produces an image.
First, I only have one camera hooked up. Am I supposed to have more than one hooked up?
Second, I re-seated the camera-mipi port cable but that did not seem to help.
Third, when I try to run i2cset, my system says âcommand not found.â Is there something else I am supposed to install?
You need at least 2 of them. Ports A and B, and C and D. In each of these two groups, at least one good camera is required. Did you purchase the set or did you purchase them separately?
I purchased the complete set (4 cams + quad HAT). I unpacked and plugged a second camera in.
All my connections are good
Installed the i2c-tools and set it to use the first camera
It worked!
Now, I would like to do some more stuff but was hoping you could point me to the documentation so that I can doodle with it before asking more questions. Some of the things I would like to do:
Turn OFF autofocus for all cameras
Take a picture with all 4 cameras at the exact same time! (I would like to do this with the press of an button at some point in time.
Label the pictures I take with with the datetime and a letter that lets me know which camera took the image (A = cam0, B-cam1, etc) like 2022-10-21_16200000A.png and 2022-10-21_16200000B.png, etc
The four cameras are sharing the clock, so you can treat him as one camera.
The camera is not auto-focused by default
Switch back to four channels.
i2cset -y 10 0x24 0x24 0x00
If you cannot turn on the camera in a four-channel situation, it means that one of the cameras is defective, please use the single-channel command to troubleshoot it in turn.See which camera is not able to produce a picture alone.
3. Iâm sorry, as I said at the beginning, they share the clock and are not separate.
After performing the upgrade, Iâm now able to complete the first example script in the picamera2 manual, section 2.3. The camera is activated, and the test.jpg image is captured!
(Iâm using a Pi 4b, 4g mem, a single Arducam 64mp camera, bullseye)
But, when I run the 3rd line below, I get some errors.
import time picam2 = Picamera2()
[0:15:37.489578871] [1709] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3897-c3c878a9
[0:15:37.502673938] [1714] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for âarducam_64mpâ
[0:15:37.502810373] [1714] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:15:37.552368109] [1714] WARN RPI raspberrypi.cpp:1280 Mismatch between Unicam and CamHelper for embedded data usage!
[0:15:37.553809695] [1714] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:15:37.554120804] [1714] INFO RPI raspberrypi.cpp:1404 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media4 and ISP device /dev/media2
camera_config = picam2.create_preview_configuration()
picam2.configure(camera_config)
[0:16:24.136443951] [1709] INFO Camera camera.cpp:1035 configuring streams: (0) 640x480-XBGR8888
[0:16:24.137373610] [1714] INFO RPI raspberrypi.cpp:765 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 1280x720-SBGGR10_1X10 - Selected unicam format: 1280x720-pBAA
Appreciate any feedback regarding the errors and warnings!
