Arducam 64MP Pi camera: libcamera-still -list-cameras unrecognised option
Hi, I’m trying to get an Arducam 64MP Pi camera running on my Raspberry Pi and it just isn’t showing up. I have a feeling the older 16MP Mini software is still installed somewhere and causing trouble.
I followed the install steps for the 64MP (page 4 of the manual):
I also added dtoverlay=vc4-kms-v3d,cma-512 under [all] in /boot/config.txt.
When I try to list cameras I get:
ERROR: *** unrecognised option ‘-list-cameras’ ***
My /boot/config.txt [all] section contains:
arm_boost=1
gpu_mem=128
dtoverlay=imx519
Other lines in there: dtparam=i2c_arm=on, dtparam=spi=on, dtparam=audio=on, camera_auto_detect=1, display_auto_detect=0, #dtoverlay=vc4-kms-v3d, max_framebuffers=2, arm_64bit=1, disable_overscan=1, and under [cm4] otg_mode=1.
What am I doing wrong here?
Thanks for all the detail, that helps a lot. A few things jump out from your config and commands:
  1. The command you ran is using a single dash. It needs to be a double dash:
    The single-dash version is what’s throwing the ‘unrecognised option’ error.
  2. From your /boot/config.txt, there’s still a dtoverlay=imx519 line. That’s a leftover for a different sensor and will conflict with the 64MP. You need to comment it out manually, so it reads:
    #dtoverlay=imx519
  3. I don’t see the arducam_64mp driver actually loaded. Make sure the kernel driver step really ran:
  4. Keep the line under [all]:
    (make sure it’s added manually under the [all] line and the old #dtoverlay=vc4-kms-v3d stays commented out).
After commenting out imx519, reinstalling the driver, and rebooting, run:
Also, can you grab a couple of system details for me?
  • Platform (Pi4 / Pi3 / CM4 etc.)
  • Output of: cat /etc/os-release
OK so I fixed the command and removed the imx519 line. I edited /boot/config.txt to comment out dtoverlay=imx519 and rebooted, but it made no difference.
Here’s what I get now with the correct command:
raspberrypi:~/Arducam $ libcamera-still --list-cameras
[0:01:35.277207839] [1871] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
No cameras available!
So it’s no longer complaining about the option, but it still says no cameras. I installed the 64MP software exactly as described on page 4 of the Arducam 64MP Pi camera manual (https://www.arducam.com/downloads/arducam_64mp_pi_camera_manual.pdf).
I also noticed the manual has a command/error on page 5 that looks off. Could that be related? I attached a screenshot of the output.
Is it possible the old 16MP Mini install is still stuck in there and needs to be uninstalled first?
Thanks, that output tells me the driver still isn’t being picked up — ‘No cameras available!’ right after the libcamera version line usually means the sensor overlay/driver didn’t load.
Can you do two things:
  1. Post the full /boot/config.txt again so I can see exactly what’s active in the [all] section now (especially that the imx519 line is commented and the vc4-kms-v3d,cma-512 line is present once).
  2. Confirm your platform and OS:
    cat /etc/os-release
    and whether this is a Pi 4, Pi 3, or CM4.
Also, it’s worth doing a clean reinstall of the pivariety packages rather than patching on top — sometimes a partial install leaves things in a weird state. Try removing and reinstalling the packages (libcamera_dev, libcamera_apps, 64mp_pi_hawk_eye_kernel_driver) in order, then reboot and run libcamera-still --list-cameras again.
Here you go.
Platform: Pi 4B 4GB
raspberrypi:~/Arducam $ cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
NAME=“Debian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=debian
HOME_URL=“https://www.debian.org/”
SUPPORT_URL=“Debian -- User Support”
BUG_REPORT_URL=“https://bugs.debian.org/”
I’ll try the clean reinstall next and report back.
Perfect, thanks. Debian 11 (bullseye) on a Pi 4B 4GB is a supported combo, so nothing there should block it.
Go ahead with the remove/reinstall cycle. To be safe, do it in this order:
  • ./install_pivariety_pkgs.sh -p libcamera_dev
  • ./install_pivariety_pkgs.sh -p libcamera_apps
  • ./install_pivariety_pkgs.sh -p 64mp_pi_hawk_eye_kernel_driver
Then double-check /boot/config.txt still has:
#dtoverlay=imx519
under [all], reboot, and run libcamera-still --list-cameras. Let me know what it reports.
Alright, I removed and reinstalled the packages and it’s working now — the camera shows up with libcamera-still --list-cameras.
One thing though: the picture is very dark. Is that expected, or is there a setting I’m missing? Otherwise the detection issue seems sorted.
Nice, glad the detection is sorted — the clean remove/reinstall of the pivariety packages was what did it, on top of commenting out the imx519 overlay and using the correct double-dash command (libcamera-still --list-cameras).
Recap of where things landed for anyone following along:
  • Platform: Raspberry Pi 4B 4GB, Debian GNU/Linux 11 (bullseye).
  • Root cause of the ‘No cameras available!’ issue: leftover imx519 overlay plus a partial driver install/ordering problem; the correct 64MP driver step is ./install_pivariety_pkgs.sh -p 64mp_pi_hawk_eye_kernel_driver, with #dtoverlay=imx519 commented out and dtoverlay=vc4-kms-v3d,cma-512 added under [all].
  • The single-dash error was just the wrong flag; it needs two dashes.
On the dark image: that’s a separate concern and it’s not fully resolved in this thread yet. It’s often exposure/gain related, so worth checking your capture command’s exposure/gain options (e.g. --shutter and --gain) and whether the lens cap/aperture ring is fully open. If it’s still dark even with manual exposure pushed up, let’s start a fresh thread with your exact libcamera-still command and a sample capture so we can dig into it.
