Arducam_64mp libcamera-vid exposure
Hi everybody,
can someone help me getting my videos on the Arducam 64mp brighter?
I am using a simple console command with libcamera-vid:
“libcamera-vid -n -t 0 --width 1920 --height 1080 --framerate 30 -b 3000000 --codec libav --libav-format flv --libav-audio --audio-device…”
The image looks quite dim especially in low light scenarios.
Is there any option to increase the exposure/gain?
I played around with the gain value which improved the image in a certain scenario, but then the auto exposure is gone.
I tried the --ev option of libcamera, but it had no effect (or I used it wrong?) :smiley:
Is there any tuning file one can use to optimize this?
Thanks in advance
Daniel
So I played around with the tuning-file “arducam_64mp.json” and got it brighter by adjusting the gain list.
When I put in higher values (around 9+) for the gain value the Automatic Gain Control makes the video “blinking/flashing” in brighter scenarios.
Do I just have some other settings wrong, what might be the reason for this?
Thanks in advance!
Here is my manipulated tuning-file:
    "version": 2.0,
    "target": "bcm2835",
    "algorithms": [
            "rpi.focus":{
            "rpi.black_level":
                "black_level": 4096
            "rpi.dpc":
            "rpi.lux":
                "reference_shutter_speed": 29966,
                "reference_gain": 2.03,
                "reference_aperture": 1.0,
                "reference_lux": 910,
                "reference_Y": 13551
            "rpi.noise":
                "reference_constant": 0,
                "reference_slope": 2.271
            "rpi.geq":
                "offset": 151,
                "slope": 0.00766
            "rpi.sdn":
                "deviation":3.7,
                "strength":0.75
            "rpi.awb":
                "priors":
                        "lux": 0, "prior":
                            2000, 1.0, 3000, 0.0, 13000, 0.0
                        "lux": 800, "prior":
                            2000, 0.0, 6000, 2.0, 13000, 2.0
                        "lux": 1500, "prior":
                            2000, 0.0, 4000, 1.0, 6000, 6.0, 6500, 7.0, 7000, 1.0, 13000, 1.0
                "modes":
                    "auto":
                        "lo": 2500,
                        "hi": 8000
                    "incandescent":
                        "lo": 2500,
                        "hi": 3000
                    "tungsten":
                        "lo": 3000,
                        "hi": 3500
                    "fluorescent":
                        "lo": 4000,
                        "hi": 4700
                    "indoor":
                        "lo": 3000,
                        "hi": 5000
                    "daylight":
                        "lo": 5500,
                        "hi": 6500
                    "cloudy":
                        "lo": 7000,
                        "hi": 8600
                "bayes": 1,
                "ct_curve":
                    2700.0, 0.8952, 0.3556, 3000.0, 0.8303, 0.3715, 4000.0, 0.6272, 0.4695, 4150.0, 0.5957, 0.4938, 6500.0, 0.4706, 0.6255
                "sensitivity_r": 1.0,
                "sensitivity_b": 1.0,
                "transverse_pos": 0.01339,
                "transverse_neg": 0.01002
            "rpi.agc":
                "metering_modes":
                    "centre-weighted":
                        "weights":
                            3, 3, 3, 2, 2, 2, 2, 1, 1, 1, 1, 0, 0, 0, 0
                    "spot":
                        "weights":
                            2, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
                    "matrix":
                        "weights":
                            1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1
                "exposure_modes":
                    "normal":
                        "shutter":
                            100, 10000, 30000, 30100, 30200, 30300, 30400
                        "gain":
                            1.0, 2.0, 4.0, 6.0, 7.0, 8.0, 9.0
                    "short":
                        "shutter":
                            100, 5000, 10000, 20000, 120000
                        "gain":
                            1.0, 2.0, 4.0, 6.0, 6.0
                "constraint_modes":
                    "normal":
                            "bound": "LOWER", "q_lo": 0.98, "q_hi": 1.0, "y_target":
                                0, 0.5, 1000, 0.5
                    "highlight":
                                0, 0.5, 1000, 0.5
                            "bound": "UPPER", "q_lo": 0.98, "q_hi": 1.0, "y_target":
                                0, 0.8, 1000, 0.8
                "y_target":
                    0, 0.16, 1000, 0.165, 10000, 0.17
            "rpi.alsc":
                "omega": 1.3,
                "n_iter": 100,
                "luminance_strength": 0.5,
                "calibrations_Cr":
                        "ct": 6500, "table":
                            2.189, 2.197, 2.203, 2.204, 2.203, 2.195, 2.189, 2.189, 2.189, 2.194, 2.204, 2.212, 2.215, 2.218, 2.213, 2.211,
                            2.196, 2.202, 2.206, 2.205, 2.201, 2.192, 2.189, 2.183, 2.184, 2.191, 2.198, 2.211, 2.218, 2.219, 2.218, 2.213,
                            2.198, 2.206, 2.206, 2.205, 2.199, 2.191, 2.182, 2.177, 2.177, 2.184, 2.196, 2.207, 2.219, 2.225, 2.225, 2.219,
                            2.199, 2.206, 2.206, 2.202, 2.197, 2.187, 2.176, 2.164, 2.164, 2.177, 2.188, 2.205, 2.218, 2.229, 2.229, 2.223,
                            2.203, 2.203, 2.204, 2.199, 2.194, 2.178, 2.164, 2.147, 2.142, 2.163, 2.178, 2.199, 2.216, 2.228, 2.228, 2.224,
                            2.206, 2.206, 2.203, 2.199, 2.192, 2.175, 2.149, 2.139, 2.133, 2.139, 2.165, 2.193, 2.212, 2.225, 2.225, 2.224,
                            2.208, 2.208, 2.208, 2.203, 2.193, 2.175, 2.149, 2.139, 2.133, 2.139, 2.165, 2.193, 2.211, 2.225, 2.225, 2.224,
                            2.215, 2.217, 2.217, 2.213, 2.204, 2.189, 2.172, 2.149, 2.147, 2.162, 2.172, 2.194, 2.211, 2.223, 2.223, 2.223,
                            2.222, 2.224, 2.229, 2.226, 2.214, 2.204, 2.188, 2.172, 2.171, 2.172, 2.184, 2.198, 2.211, 2.221, 2.221, 2.217,
                            2.224, 2.231, 2.233, 2.231, 2.226, 2.214, 2.201, 2.188, 2.184, 2.184, 2.191, 2.198, 2.211, 2.212, 2.214, 2.207,
                            2.224, 2.233, 2.235, 2.234, 2.229, 2.219, 2.209, 2.198, 2.191, 2.191, 2.196, 2.201, 2.203, 2.208, 2.204, 2.195,
                            2.219, 2.226, 2.234, 2.234, 2.231, 2.222, 2.212, 2.203, 2.196, 2.196, 2.198, 2.202, 2.202, 2.203, 2.195, 2.192
                "calibrations_Cb":
                            1.329, 1.329, 1.329, 1.337, 1.347, 1.355, 1.363, 1.367, 1.366, 1.359, 1.351, 1.342, 1.331, 1.321, 1.319, 1.317,
                            1.329, 1.329, 1.334, 1.339, 1.349, 1.358, 1.367, 1.373, 1.373, 1.366, 1.356, 1.344, 1.333, 1.322, 1.319, 1.315,
                            1.329, 1.334, 1.339, 1.349, 1.356, 1.365, 1.373, 1.379, 1.376, 1.373, 1.361, 1.348, 1.339, 1.329, 1.319, 1.315,
                            1.337, 1.343, 1.349, 1.356, 1.365, 1.374, 1.379, 1.383, 1.383, 1.376, 1.367, 1.356, 1.346, 1.337, 1.327, 1.319,
                            1.345, 1.351, 1.358, 1.366, 1.374, 1.379, 1.384, 1.387, 1.387, 1.382, 1.374, 1.364, 1.354, 1.344, 1.334, 1.326,
                            1.352, 1.358, 1.366, 1.374, 1.379, 1.386, 1.391, 1.393, 1.391, 1.387, 1.379, 1.369, 1.358, 1.347, 1.336, 1.326,
                            1.356, 1.362, 1.369, 1.377, 1.385, 1.389, 1.393, 1.395, 1.394, 1.388, 1.379, 1.369, 1.358, 1.347, 1.336, 1.326,
                            1.356, 1.362, 1.369, 1.377, 1.383, 1.388, 1.393, 1.394, 1.393, 1.387, 1.377, 1.367, 1.356, 1.346, 1.334, 1.326,
                            1.353, 1.359, 1.364, 1.369, 1.377, 1.383, 1.388, 1.389, 1.387, 1.381, 1.371, 1.361, 1.351, 1.341, 1.331, 1.324,
                            1.349, 1.353, 1.359, 1.363, 1.368, 1.374, 1.379, 1.381, 1.381, 1.371, 1.362, 1.353, 1.344, 1.335, 1.326, 1.319,
                            1.345, 1.346, 1.349, 1.353, 1.358, 1.364, 1.369, 1.369, 1.368, 1.362, 1.354, 1.344, 1.336, 1.327, 1.319, 1.318,
                            1.345, 1.345, 1.345, 1.349, 1.353, 1.358, 1.361, 1.361, 1.361, 1.355, 1.347, 1.338, 1.331, 1.322, 1.319, 1.318
                "luminance_lut":
                    3.893, 3.682, 3.101, 2.704, 2.357, 2.074, 1.985, 1.977, 1.977, 1.977, 2.041, 2.316, 2.666, 3.057, 3.627, 3.831,
                    3.682, 3.175, 2.714, 2.418, 2.072, 1.856, 1.712, 1.636, 1.636, 1.689, 1.821, 2.028, 2.376, 2.678, 3.128, 3.627,
                    3.177, 2.839, 2.421, 2.072, 1.847, 1.579, 1.434, 1.359, 1.359, 1.416, 1.545, 1.801, 2.028, 2.376, 2.797, 3.128,
                    2.991, 2.621, 2.206, 1.851, 1.579, 1.428, 1.226, 1.151, 1.151, 1.208, 1.395, 1.545, 1.801, 2.151, 2.579, 2.949,
                    2.915, 2.479, 2.061, 1.709, 1.433, 1.226, 1.146, 1.015, 1.013, 1.127, 1.208, 1.395, 1.661, 2.001, 2.433, 2.876,
                    2.915, 2.419, 1.989, 1.641, 1.361, 1.151, 1.015, 1.007, 1.001, 1.009, 1.127, 1.325, 1.594, 1.934, 2.371, 2.876,
                    2.915, 2.419, 1.989, 1.641, 1.361, 1.151, 1.013, 1.004, 1.001, 1.005, 1.127, 1.325, 1.594, 1.934, 2.371, 2.876,
                    2.922, 2.493, 2.063, 1.709, 1.434, 1.223, 1.146, 1.012, 1.008, 1.127, 1.205, 1.399, 1.666, 2.013, 2.449, 2.884,
                    3.009, 2.634, 2.209, 1.849, 1.582, 1.434, 1.223, 1.146, 1.146, 1.205, 1.399, 1.556, 1.811, 2.168, 2.601, 2.971,
                    3.221, 2.867, 2.437, 2.088, 1.849, 1.582, 1.441, 1.365, 1.365, 1.425, 1.556, 1.811, 2.059, 2.403, 2.836, 3.186,
                    3.755, 3.221, 2.759, 2.437, 2.088, 1.871, 1.726, 1.652, 1.652, 1.711, 1.846, 2.059, 2.403, 2.748, 3.186, 3.723,
                    3.951, 3.755, 3.157, 2.739, 2.383, 2.099, 2.019, 2.016, 2.016, 2.016, 2.086, 2.353, 2.713, 3.136, 3.723, 3.911
                "sigma": 0.005,
                "sigma_Cb": 0.005
            "rpi.contrast":
                "ce_enable": 1,
                "gamma_curve":
                    0, 0, 1024, 5040, 2048, 9338, 3072, 12356, 4096, 15312, 5120, 18051, 6144, 20790, 7168, 23193,
                    8192, 25744, 9216, 27942, 10240, 30035, 11264, 32005, 12288, 33975, 13312, 35815, 14336, 37600, 15360, 39168,
                    16384, 40642, 18432, 43379, 20480, 45749, 22528, 47753, 24576, 49621, 26624, 51253, 28672, 52698, 30720, 53796,
                    32768, 54876, 36864, 57012, 40960, 58656, 45056, 59954, 49152, 61183, 53248, 62355, 57344, 63419, 61440, 64476,
                    65535, 65535
            "rpi.ccm":
                "ccms":
                        "ct": 2700, "ccm":
                            1.24141, 0.35437, -0.59578, -0.51309, 1.87147, -0.35838, -0.31548, -1.11436, 2.42984
                        "ct": 3000, "ccm":
                            1.46878, -0.28074, -0.18804, -0.41877, 1.41722, 0.00154, -0.12837, -0.98072, 2.10909
                        "ct": 4000, "ccm":
                            1.43532, -0.25531, -0.18002, -0.35574, 1.46911, -0.11336, -0.12509, -0.60778, 1.73287
                        "ct": 4150, "ccm":
                            1.70003, -0.58839, -0.11165, -0.43727, 1.47037, -0.03311, -0.13077, -0.51345, 1.64422
                        "ct": 6500, "ccm":
                            1.53197, -0.25773, -0.27423, -0.32591, 1.57394, -0.24803, -0.17084, -0.30841, 1.47925
            "rpi.sharpen":
                "threshold":1.5,
                "strength":0.5,
                "limit":0.2
Has someone expertise in tuning files please :frowning:
