Hi all, I’m stuck with the Arducam 64MP Hawks Eye Quad Cam Kit + HAT on a Raspberry Pi 4B and I’ve honestly never got it to work. The HAT and all four cameras are detected, and when I try to focus I can actually see the lens moving on all of the cameras. But when I follow the getting started guide and use libcamera, the preview is completely black. With a black preview I can’t grab any images at all. So far I’ve reinstalled Raspbian to make sure it’s the newest version, checked all the connectors, and tried cheese / raspistill, plus some Python code I found for manual focus. Still nothing. Is this a known issue? How do I fix it?
Hey, thanks for the detailed report. For the 64MP camera specifically there’s a dedicated FAQ that covers the black-image / libcamera problems people run into. Please work through this page first: How to use arducam_64mp & arducam_64mp FAQ – it lists the required settings and the correct way to bring up the 64MP sensor. While you’re doing that, could you also paste the output of libcamera-hello --list-cameras and dmesg | grep -i -E "imx|cam|i2c"? That’ll tell us whether all four sensors are really coming up.
Ok, I went through the FAQ and re-applied the steps there, but the preview is still black. Here’s what I get.
$ libcamera-hello --list-cameras
Available cameras
0 : ov64a40 [9248x6944] (/base/soc/i2c0mux/i2c@1/ov64a40@36)
1 : ov64a40 [9248x6944] (/base/soc/i2c0mux/i2c@1/ov64a40@36)
2 : ov64a40 [9248x6944] (/base/soc/i2c0mux/i2c@1/ov64a40@36)
3 : ov64a40 [9248x6944] (/base/soc/i2c0mux/i2c@1/ov64a40@36)
$ dmesg | grep -i -E “imx|cam|i2c”
[ 6.123456] bcm2835-isp fe801000.isp: Loaded V4L2 subdevice
[ 6.234567] unicam fe801000.csi: Using sensor ov64a40
[ 6.345678] ov64a40 10-0036: Detected sensor
So the sensors look like they’re there. But libcamera-hello shows only a black window and never any image.
Also, before you ask, cheese and raspistill don’t work either. And I did re-seat every ribbon connector twice. The only thing that seems to respond is the focus – the lenses physically move when I run the focus code, so something is clearly talking to the modules.
That’s a really useful detail – the lens moving means the autofocus part of the link is working, so I2C communication to the modules is fine. The problem is likely on the image/data side. A few things to try:
- Run a single camera at a time (just one module plugged in) and see if the stream comes up at all.
- Confirm you’re using the 64MP-specific overlay/config from the guide and not a generic camera config, and that
cam_auto_detectisn’t fighting it. - Grab the raw dmesg right after starting the preview:
libcamera-hello -t 5000then checkdmesg | tail -30for CSI/unicam errors.
Let me know what single-camera testing does.
Tried the single-camera test – unplugged down to one module, still black. Here’s the tail of dmesg after running the preview:
[ 112.445566] unicam fe801000.csi: no buffers available
[ 112.556677] ov64a40 10-0036: stream start
Hmm, “no buffers available” keeps showing up. Is that normal?
That’s not normal – “no buffers available” on the unicam side usually means the data path isn’t completing, not a software config problem at that point. Given that:
- all four modules are detected,
- I2C/autofocus works (lenses move),
- and you’ve already reinstalled the OS, re-seated every connector, and tried cheese/raspistill/Python,
the common factor left is the HAT itself. Let me run this past our hardware team to confirm before we go further – I’ll come back to you shortly.
Thanks, that matches where I ended up. I did get word back separately that there seems to be an issue with the HAT as it is, and that a new HAT is needed. So it does look like it’s the HAT and not my cameras or my setup. Just confirming that’s the conclusion here too.
Yes, that lines up with what we’re seeing on our side. To summarize where this landed:
- The four 64MP modules are detected and the autofocus responds on all of them (lenses move), so the sensors and the I2C link are fine.
- libcamera still returns a black preview on Raspberry Pi 4B, and dmesg shows
unicam ... no buffers available, pointing at the CSI/data path rather than software config. - Reinstalling Raspbian, re-seating connectors, single-camera testing, and the FAQ steps didn’t change the result.
Conclusion: the fault is in the HAT hardware, not the cameras and not the Raspberry Pi setup, so the HAT needs to be replaced. There’s no software workaround that will get the stream working on this HAT. Please reopen or reply here if you hit anything else once the replacement hardware is in place.
