Bought when it first became available from ArduCam -
Hawkeye 64MP -
Raspberry PI 4 -
64MP Hawkeye - Arducam Wiki -
After update camera not found -
Currently I am trying arducam-pivariety
root@raspberrypi:~# dmesg |grep ardu
[ 0.078551] platform fe800000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@0/arducam_pivariety@c
[ 8.733194] arducam-pivariety 0-000c: pivariety_read: Reading register 0x103 failed
[ 8.733258] arducam-pivariety 0-000c: probe failed -
I tried new OS,
several other versions.
Disconnected cable and reconnected.
Tried several different /boot/config.txt options
I tried the new os with /boot/firmware/config.txt -
Steps to make the camera work again.
It’s more or less weird because your post didn’t explain it as clearly as possible.
Since you are using a Hawkeye 64mp camera, why didn’t you choose to enable the camera driver with dtoverlay like dtoverlay=arducam-64mp?
I tried the arducam-pivariety after reading the readme for the driver at GitHub - ArduCAM/Arducam-Pivariety-V4L2-Driver: This driver is used for Arducam mipi camera with Pivariety board
I have it switched back to the arducam-64mp now.
dave@raspberrypi:~ $ sudo su -
[ 0.079486] platform fe800000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@0/arducam_64mp@1a
[ 9.003972] arducam_64mp: loading out-of-tree module taints kernel.
[ 9.078815] arducam_64mp 0-001a: failed to read chip id 4136, with error -5
[ 9.108494] arducam_64mp: probe of 0-001a failed with error -5
root@raspberrypi:~# tail /boot/config.txt
[pi4]
arm_boost=1
enable_uart=1
dtparam=i2c_vc=on
dtparam=i2c_arm=on
dtoverlay=arducam-64mp,cam0,media-controller=0
#dtoverlay=arducam-pivariety,cam0
root@raspberrypi:~# libcamera-still --list-cameras
No cameras available!
root@raspberrypi:~#
that error in dmesg is where I think the problem is which is why I tried to use the driver that is in the stock kernel.
It looks to me like the kernel module loaded fine.
root@raspberrypi:~/arducam# lsmod |grep ardu
arducam_64mp 24576 0
v4l2_fwnode 24576 2 bcm2835_unicam,arducam_64mp
v4l2_async 24576 4 v4l2_fwnode,bcm2835_unicam,arducam_64mp,dw9807_vcm
videodev 274432 11 v4l2_async,bcm2835_codec,videobuf2_v4l2,bcm2835_unicam,bcm2835_v4l2,arducam_64mp,videobuf2_common,rpivid_hevc,dw9807_vcm,v4l2_mem2mem,bcm2835_isp
mc 61440 11 v4l2_async,videodev,bcm2835_codec,videobuf2_v4l2,bcm2835_unicam,arducam_64mp,videobuf2_common,rpivid_hevc,dw9807_vcm,v4l2_mem2mem,bcm2835_isp
The camera works in an old version of the OS from 2022.
Hi @r1220gsdave,
Since the camera can work on the old version of the OS, you can flash a new image with the latest OS onto your SD card and then follow the steps in the link below to configure your Pi so that the camera module works.
https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/64MP-Hawkeye/#raspberry-pi-bullseye-os-6121-and-laterbookworm-os
The camera works now on the latest. Thanks
