Hi, I’m trying to get an Arducam 64MP Ultra High-Res camera (the one from https://www.arducam.com/64mp-ultra-high-res-camera-raspberry-pi/) working on a Pi 4B and I’ve never been able to get it to work at all. On a fresh install with what I’m pretty sure is a good ribbon cable, all I ever get is:
I’ve already tried a fresh install, reseated the cable, and I checked the cord and the Pi itself with another camera (I switched to legacy mode for that test, then switched it back). I also followed the April 2022 64MP Pi Camera Manual step by step. I can’t tell if the unit is just faulty or if there’s some software fix I’m missing. Any help would be great.
Hi, welcome. Let’s dig into this. A couple of quick things first:
Which OS image are you running? (Bullseye vs the older Buster, and 32-bit vs 64-bit)
When you say you “switched back” from legacy mode, can you confirm the legacy camera stack is actually disabled under raspi-config > Interface Options > Legacy Camera (should be set to No)?
Important note: the 64MP camera is developed against the Bullseye libcamera stack and cannot run on the legacy camera stack. If legacy mode is enabled, it will not be detected at all, which matches the “no cameras available” error you’re seeing.
It’s a fresh Bullseye install, 32-bit (armhf). Here’s the output you asked for:
$ dpkg -l | grep libcamera
ii libcamera-apps 0.0.7 armhf libcamera-apps
ii libcamera-dev 0.0.7 armhf libcamera
I followed the April 2022 64MP Pi Camera Manual for the setup. For the test with the other camera I did switch to legacy mode, but I switched it back afterwards, so legacy should be off now. Still only getting “ERROR: *** no cameras available ***”.
Your libcamera packages are at version 0.0.7, which is the older set. The 64MP driver-side support expects the newer Bullseye libcamera stack.
More importantly, the 64MP camera simply cannot be used on the legacy camera stack. It was developed on Bullseye, so if any part of the legacy setup is still active, the sensor won’t be detected.
Please double-check that Legacy Camera is disabled (raspi-config > Interface Options > Legacy Camera → No), reboot, and then run these two commands and paste the output:
Preview window unavailable
[0:03:29.558483519] [1351] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
Bug report generated to bug.txt
Please upload this file when you create a new bug report at: Issues · raspberrypi/rpicam-apps · GitHub
So the libcamera-still capture still fails with no cameras available.
That’s the expected failure signature on a stack that isn’t exposing the sensor. The libcamera log shows the camera manager starting (libcamera v0.0.0+3572-e13ccdd5) but zero sensors enumerated, which is why libcamera-still bails immediately.
Please attach the bug.txt that was generated on the Pi. That file contains the full probe/dmesg info we need to confirm whether the sensor is being seen on the I2C bus at all.
Thanks for the file, I went through it. Here’s where we are:
Root cause: the 64MP camera is not supported on the legacy camera stack. It requires the Bullseye system with the libcamera stack. Your logs show libcamera enumerating with no cameras available, which is what we expect when the module is being handled by the wrong stack / incomplete libcamera support rather than the 64MP driver path.
What to do:
Make sure you’re on a clean Bullseye install (32-bit is fine) with Legacy Camera disabled, and let the camera be driven through the libcamera stack only - not legacy.
Your libcamera packages are at 0.0.7; make sure you’ve installed the 64MP setup from the April 2022 manual on top of that Bullseye base.
To keep going, I still need the two things from the last post on your end so we can rule the hardware in or out:
If everything checks out on a properly configured Bullseye + libcamera stack and it still shows no cameras available, that points to the module itself and we can take it from there.
