Arducam 64MP camera not detected on Raspberry Pi, driver install fails on Buster
Hi, I just got an Arducam 64MP camera (the pi_hawk_eye one) and I can’t get it to work on my Raspberry Pi at all. I’m pretty sure it’s not the Pi itself because my other Raspberry cameras work fine on the same board. When I run:
vcgencmd get_camera
I get:
supported=1 detected=0
So it says the camera system is supported but nothing is detected. I went to this troubleshooting page thinking I just needed to install the driver:
https://www.arducam.com/docs/cameras-for-raspberry-pi/64mp-camera-for-raspberry-pi/64mp-camera-troubleshooting/
But the install instructions failed on me and printed this:
Hardware Revision: b03114
Kernel Version: 5.10.95-v7l+
Package: 64mp_pi_hawk_eye_kernel_driver – buster
You are using an unsupported kernel version, please install the official SD Card image(do not execute rpi-update):
https://www.raspberrypi.com/software/operating-systems/
Any idea what’s going on? I feel like I’m missing something obvious.
Thanks for the details, and no, you’re not missing anything obvious — this is a known mismatch between the driver package and the kernel you’re running. Can you confirm a few things so I can narrow it down?
  1. What does uname -a show?
  2. Are you on a fresh Raspberry Pi OS install, or did you update the kernel at some point (e.g. rpi-update)?
  3. Can you paste the exact output of:
vcgencmd get_camera
to confirm the supported=1 detected=0 result?
Sure. uname -a gives me:
Linux raspberrypi 5.10.95-v7l+ #1594 SMP … armv7l GNU/Linux
Hardware revision is b03114, and it’s a Raspberry Pi (the 4 I think, given the v7l+ kernel). Definitely not a fresh image — I’ve had this SD card running a while and I’ve messed with it here and there. I don’t remember running rpi-update specifically, but I might have at some point.
And yes, vcgencmd get_camera still gives:
Same as before.
Oh also — I forgot to mention the exact package string the install script complained about. It said:
So it looks like it’s trying to grab a driver built for buster, but my kernel keeps getting flagged as unsupported.
That lines up with what I suspected. The diagnostic block you’re getting is the driver installer telling you it can’t find a prebuilt package for your current kernel. It shows these three values:
  • Hardware Revision: b03114
  • Kernel Version: 5.10.95-v7l+
  • Package: 64mp_pi_hawk_eye_kernel_driver – buster
and then explicitly says: “You are using an unsupported kernel version.”
The 64mp_pi_hawk_eye_kernel_driver package was built for the buster era. Your current kernel (5.10.95-v7l+) is outside the range that package supports, so the installer bails out. The supported=1 detected=0 from vcgencmd get_camera is consistent with that — the camera subsystem is enabled, but without the matching driver the 64MP sensor never gets detected.
Can you tell me the output of cat /etc/os-release and cat /proc/version? I want to see exactly what OS release you’re sitting on.
Here you go:
/etc/os-release:
PRETTY_NAME=“Raspbian GNU/Linux 10 (buster)”
VERSION_ID=“10”
/proc/version:
Linux version 5.10.95-v7l+ (dom@buildbot) … gcc version 8.3.0 …
So it’s Raspbian buster, but the kernel is 5.10.95 which apparently the driver package doesn’t like. Is there any way to make this work without wiping my card? I’ve got a lot of stuff set up on this SD card.
I get it — wiping a card you’ve customized is annoying. A few things we can try first before you go the reinstall route:
  1. Make sure the camera cable is fully seated on both ends and inserted the correct way (contacts facing the right direction on the Pi’s CSI port). A loose ribbon gives you detected=0 too.
  2. Check that the camera interface is actually enabled: raspi-config → Interface Options → Legacy Camera, or check /boot/config.txt for start_x=1 and gpu_mem=128.
  3. Confirm there’s only one camera line in /boot/config.txt and nothing conflicting.
Can you check those and also paste the output of grep -i camera /boot/config.txt?
Okay, checked all of that:
  • Ribbon cable is seated properly, swapped it out with a known-good one just to be sure — same result.
  • grep -i camera /boot/config.txt gives nothing camera-related except the default lines, and start_x=1 / gpu_mem=128 are set.
  • Tried the camera on a second spare Pi I have lying around — same supported=1 detected=0.
So I really don’t think it’s the cable or the Pi. When I swap in my older Raspberry camera, it just works.
Thanks for testing on a second Pi — that rules out the hardware and the ribbon. Since the older Raspberry camera works and the 64MP doesn’t, and the driver installer is rejecting your kernel, the blocker really is the OS/kernel version, not the camera.
Can you run the installer once more and paste the full output? I want to see whether it offers any fallback or just refuses outright.
Ran it again, same thing every time:
No fallback, it just exits. And it specifically says don’t run rpi-update. So I’m guessing that’s a dead end.
Yeah, it’s a dead end for that install path. Here’s the situation in a nutshell:
  • Your kernel (5.10.95-v7l+) is flagged as unsupported by the 64mp_pi_hawk_eye_kernel_driver package, which was built for buster.
  • vcgencmd get_camera returning supported=1 detected=0 means the camera stack is on, but the sensor isn’t detected — because the driver isn’t loaded/matched.
  • Your Pi and cable are fine, proven by the older camera working and by testing on a second board.
Our recommendation is to reinstall the latest Raspberry Pi system from the official SD Card image rather than trying to patch the current kernel:
Important: do NOT run rpi-update. That pulls a bleeding-edge kernel and is exactly how people end up on an unsupported kernel version like the one you’re on. Use the official image instead.
Ah, that makes sense — so it’s the kernel version that’s killing me, not the camera. I’ll grab a spare card, flash the latest official image, and try the driver install on a clean system. If it still fails I’ll come back with the new kernel output.
Thanks for walking me through it. I was chasing cables and configs when the whole time the kernel was the issue.
Sounds good. To recap for anyone else finding this thread:
  • Symptom: vcgencmd get_camera → supported=1 detected=0 on a 64MP pi_hawk_eye camera, while other Raspberry cameras work fine.
  • Root cause: the 64mp_pi_hawk_eye_kernel_driver package was built for buster and does not support the current kernel (5.10.95-v7l+), so the installer refuses with “You are using an unsupported kernel version.”
  • Conclusion: the OS/kernel version is the blocker. Fix is to reinstall the latest official Raspberry Pi OS from the official SD Card image (https://www.raspberrypi.com/software/operating-systems/) and NOT run rpi-update, since that leads to unsupported kernel versions.
Once you’re on the latest official image, run the driver install again and the sensor should get detected. Let us know how it goes.
