Arducam 64MP Autofocus Quad-Camera Kit Not Working
Dear Community,
Since yesterday, I’ve had 4 x 64MP ArduCams with the MultiArray Hat UC-512. Unfortunately, I can’t get the cameras to work on a Raspberry PI5.
I started by performing a fresh installation of Bookworm. Then, following the instructions at:
https://docs.arducam.com/Raspberry-Pi-Camera/Multi-Camera-CamArray/quick-start/#imx519-multi-camera-kit
It was basically following steps:
My config.txt looks like this.
# http://rptl.io/configtxt
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=0
display_auto_detect=1
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d,cma-512
max_framebuffers=2
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
dtoverlay=arducam-64mp,cam0
rpicam-still --list-cameras show one found camera. So far so good I guess:
user@raspberrypi:~ $ rpicam-still --list-cameras
Available cameras
0 : arducam_64mp [9248x6944 10-bit RGGB] (/base/axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a)
    Modes: 'SRGGB10_CSI2P' : 1280x720 [120.09 fps - (2064, 2032)/5120x2880 crop]
                             1920x1080 [60.04 fps - (784, 1312)/7680x4320 crop]
                             2312x1736 [30.00 fps - (0, 0)/9248x6944 crop]
                             3840x2160 [20.00 fps - (784, 1312)/7680x4320 crop]
                             4624x3472 [10.00 fps - (0, 0)/9248x6944 crop]
                             8000x6000 [3.00 fps - (624, 472)/9248x6944 crop]
                             9152x6944 [2.70 fps - (0, 0)/9248x6944 crop]
But when I try to capture an image I get following error:
user@raspberrypi:~ $ rpicam-still -o test.jpg --timeout 5000
[0:06:07.532915005] [852]  INFO Camera camera_manager.cpp:330 libcamera v0.5.2+125-69c6546d-dirty (2025-09-12T07:28:55BST)
[0:06:07.544090634] [855]  INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:13:50)
[0:06:07.552517888] [855]  INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/pisp/arducam_64mp.json
[0:06:07.562947113] [855]  INFO Camera camera_manager.cpp:220 Adding camera '/base/axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a' for pipeline handler rpi/pisp
[0:06:07.562991132] [855]  INFO RPI pisp.cpp:1180 Registered camera /base/axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a to CFE device /dev/media2 and ISP device /dev/media0 using PiSP variant BCM2712_C0
WARNING: Capture will not make use of temporal denoise
         Consider using the --zsl option for best results, for example:
Made DRM preview window
Preview window unavailable
Mode selection for 4624:3472:12:P
    SRGGB10_CSI2P,1280x720/0 - Score: 13359.2
    SRGGB10_CSI2P,1920x1080/0 - Score: 11359.2
    SRGGB10_CSI2P,2312x1736/0 - Score: 9096
    SRGGB10_CSI2P,3840x2160/0 - Score: 5359.24
    SRGGB10_CSI2P,4624x3472/0 - Score: 1000
    SRGGB10_CSI2P,8000x6000/0 - Score: 2476.58
    SRGGB10_CSI2P,9152x6944/0 - Score: 3041.47
Stream configuration adjusted
[0:06:07.571927216] [852]  INFO Camera camera.cpp:1215 configuring streams: (0) 4624x3472-YUV420/sYCC (1) 4624x3472-RGGB_PISP_COMP1/RAW
[0:06:07.572060901] [855]  INFO RPI pisp.cpp:1484 Sensor: /base/axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10/RAW - Selected CFE format: 4624x3472-PC1R/RAW
[0:06:09.012697408] [855]  WARN V4L2 v4l2_videodevice.cpp:2155 /dev/video4[14:cap]: Dequeue timer of 1000000.00us has expired!
[0:06:09.012767093] [855] ERROR RPI pipeline_base.cpp:1408 Camera frontend has timed out!
[0:06:09.012782185] [855] ERROR RPI pipeline_base.cpp:1409 Please check that your camera sensor connector is attached securely.
[0:06:09.012796556] [855] ERROR RPI pipeline_base.cpp:1410 Alternatively, try another cable and/or sensor.
I tried around using some AI tool, but it seems not to work. I would really appreciate it if someone could help me.
AI wanted to take a look to the multiplexer of the UC-512 and to the Kernel messages, so I will share it to you, too:
user@raspberrypi:~ $ dmesg | grep -iE "arducam|csi|cfe|ov64|overlay"
[    1.090358] /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[    1.102175] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a
[    1.114082] /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[    1.125897] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a
[    1.168367] SCSI subsystem initialized
[    1.562391] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.729390] Loading iSCSI transport class v2.0-870.
[    2.345405] /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[    2.357531] /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[    2.369336] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a
[    2.879400] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a
[    2.892916] /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[    4.742444] rp1-cfe 1f00110000.csi: bcm2712_iommu_of_xlate: MMU 1000005280.iommu
[    4.742451] rp1-cfe 1f00110000.csi: bcm2712_iommu_probe_device: MMU 1000005280.iommu
[    4.742456] rp1-cfe 1f00110000.csi: bcm2712_iommu_device_group: MMU 1000005280.iommu
[    4.742460] rp1-cfe 1f00110000.csi: Adding to iommu group 2
[    4.742464] rp1-cfe 1f00110000.csi: bcm2712_iommu_attach_dev: MMU 1000005280.iommu
[    4.750495] rp1-cfe 1f00110000.csi: DW dphy Host HW v1.20
[    4.750525] rp1-cfe 1f00110000.csi: PiSP FE HW v0.1
[    4.750728] rp1-cfe 1f00110000.csi: found subdevice /axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a
[    4.808517] arducam_64mp 10-001a: Device found Arducam 64MP.
[    4.828630] rp1-cfe 1f00110000.csi: Using sensor arducam_64mp 10-001a for capture
[    4.829065] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-csi2_ch0] node id 0 successfully as /dev/video0
[    4.831504] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-embedded] node id 1 successfully as /dev/video1
[    4.831695] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-csi2_ch2] node id 2 successfully as /dev/video2
[    4.831750] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-csi2_ch3] node id 3 successfully as /dev/video3
[    4.840516] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-fe_image0] node id 4 successfully as /dev/video4
[    4.840560] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-fe_image1] node id 5 successfully as /dev/video5
[    4.840597] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-fe_stats] node id 6 successfully as /dev/video6
[    4.840738] rp1-cfe 1f00110000.csi: Registered [rp1-cfe-fe_config] node id 7 successfully as /dev/video7
[  368.160251] rp1-cfe 1f00110000.csi: Using a link rate of 912 Mbps
[  369.487774] rp1-cfe 1f00110000.csi: Using a link rate of 912 Mbps
[  378.948797] rp1-cfe 1f00110000.csi: Using a link rate of 912 Mbps
[  380.276522] rp1-cfe 1f00110000.csi: Using a link rate of 912 Mbps
[  381.604630] rp1-cfe 1f00110000.csi: Using a link rate of 912 Mbps
user@raspberrypi:~ $ i2cdetect -y 10
00:                         -- -- -- -- UU -- -- --
10: -- -- -- -- -- -- -- -- -- -- UU -- -- -- -- --
20: -- -- -- -- 24 -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
user@raspberrypi:~ $ i2cdump -y 10 0x24 b
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 22 00 00 00 00 17 0a 17 00 00 00 00 00 00 00 00    "....???........
10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
Grettings
Christian Wendt
Just wondering if the cable length of 30 cm is too long for the frequency used. Could it be? Because I see a much shorter cable for Raspberry PI4…
Hi! Some Update: I found a Raspberry PI4 and tried again. Now it works! So only difference (next to the different Raspberry version) is the cable.
Hi there,
Glad to see the Quad-cam Kit works on a Raspberry Pi 4, which helps us rule out the potential hardware issues.
Regarding the timeout error on Pi 5, looks like the cable between the HAT board and the Raspberry Pi was broken or something like that.
Did you try the shorter white cable that came with the Kit in the package?
thank you for your repsonse. Unfortunately, there was only a long white cable in the box. Okay, if that one’s broken, I’ll try to get a replacement. Or where can I buy a shorter one?
Greetings
Hi
Here’s the product link for the cable: 80mm 22 pin camera cable
Hello again!
I got this cable and tried again. This time the green LED on the hat next to the 3V3 is continuously blinking but still the camera got a front end timeout.
user@eduardv3:~ $ rpicam-still -o test.jpg --timeout 5000
[0:04:40.933910412] [3653]  INFO Camera camera_manager.cpp:330 libcamera v0.5.2+125-69c6546d-dirty (2025-09-12T07:28:55BST)
[0:04:40.945122307] [3656]  INFO RPI pisp.cpp:720 libpisp version v1.2.1 981977ff21f3 29-04-2025 (14:13:50)
[0:04:40.950401026] [3656]  INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/pisp/arducam_64mp.json
[0:04:40.959308605] [3656]  INFO Camera camera_manager.cpp:220 Adding camera '/base/axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a' for pipeline handler rpi/pisp
[0:04:40.959348475] [3656]  INFO RPI pisp.cpp:1180 Registered camera /base/axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a to CFE device /dev/media2 and ISP device /dev/media0 using PiSP variant BCM2712_C0
Made X/EGL preview window
[0:04:40.982717776] [3653]  INFO Camera camera.cpp:1215 configuring streams: (0) 4624x3472-YUV420/sYCC (1) 4624x3472-RGGB_PISP_COMP1/RAW
[0:04:40.982856812] [3656]  INFO RPI pisp.cpp:1484 Sensor: /base/axi/pcie@1000120000/rp1/i2c@88000/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10/RAW - Selected CFE format: 4624x3472-PC1R/RAW
[0:04:42.371043431] [3656]  WARN V4L2 v4l2_videodevice.cpp:2155 /dev/video4[21:cap]: Dequeue timer of 1000000.00us has expired!
[0:04:42.371086857] [3656] ERROR RPI pipeline_base.cpp:1408 Camera frontend has timed out!
[0:04:42.371092431] [3656] ERROR RPI pipeline_base.cpp:1409 Please check that your camera sensor connector is attached securely.
[0:04:42.371097116] [3656] ERROR RPI pipeline_base.cpp:1410 Alternatively, try another cable and/or sensor.
[0:04:43.692140195] [3656]  WARN V4L2 v4l2_videodevice.cpp:2155 /dev/video4[21:cap]: Dequeue timer of 1000000.00us has expired!
[0:04:43.692192028] [3656] ERROR RPI pipeline_base.cpp:1408 Camera frontend has timed out!
[0:04:43.692201935] [3656] ERROR RPI pipeline_base.cpp:1409 Please check that your camera sensor connector is attached securely.
[0:04:43.692211454] [3656] ERROR RPI pipeline_base.cpp:1410 Alternatively, try another cable and/or sensor.
[0:04:45.013152770] [3656]  WARN V4L2 v4l2_videodevice.cpp:2155 /dev/video4[21:cap]: Dequeue timer of 1000000.00us has expired!
[0:04:45.013203826] [3656] ERROR RPI pipeline_base.cpp:1408 Camera frontend has timed out!
[0:04:45.013210307] [3656] ERROR RPI pipeline_base.cpp:1409 Please check that your camera sensor connector is attached securely.
[0:04:45.013215418] [3656] ERROR RPI pipeline_base.cpp:1410 Alternatively, try another cable and/or sensor.
[0:04:46.334998744] [3656]  WARN V4L2 v4l2_videodevice.cpp:2155 /dev/video4[21:cap]: Dequeue timer of 1000000.00us has expired!
[0:04:46.335053003] [3656] ERROR RPI pipeline_base.cpp:1408 Camera frontend has timed out!
[0:04:46.335061448] [3656] ERROR RPI pipeline_base.cpp:1409 Please check that your camera sensor connector is attached securely.
[0:04:46.335068855] [3656] ERROR RPI pipeline_base.cpp:1410 Alternatively, try another cable and/or sensor.
I work with original Raspberry power supply, so I think its not a power issue. Any ideas? Is there a way to debug this? We really would like to run the cameras on PI5, because we want and love your cameras and the PI4 is to slow to do any proper application with that.
I hope we can fix this. Greetings
Christian
Hi there,
Did you have all four camera modules connected to the HAT board when running the rpicam-still command?
Good morning,
Yeah, exactly—I just plugged the “hat” from the PI4 into the PI5. The cameras are still connected. And of course, I replaced the cable from the “hat” to the Raspberry.
