Arducam 64MP Auto Focus camera: libcamera-hello reports 'no cameras available' on Raspberry Pi 4B
Hi, I’m stuck with an Arducam 1/1.32" 64MP Auto Focus Camera Module on a Raspberry Pi 4B. I flashed B0528_arducam-64mp-2024-07-26-2024-07-04-raspios-bookworm-arm64.img and when I run libcamera-hello I get:
libcamera-hello ERROR: *** no cameras available ***
I’ve already done a fresh install, checked that the CSI ribbon cable is seated properly, and tested with another image plus an Arducam 16MP module (that one is detected fine), so I don’t think the Pi or the connector is the problem. No custom code involved, just the default libcamera test. Any ideas?
Can you check the model marking printed on the camera board itself? The image B0528_arducam-64mp-2024-07-26-2024-07-04-raspios-bookworm-arm64.img is built for the Arducam 64MP Autofocus Camera Module (B0339/B0399). The 1/1.32" 64MP Auto Focus Camera Module is B0483, and it uses a different driver/dtoverlay setup, so that image won’t detect it. If your board is marked B0483, that explains why libcamera reports no cameras available.
Just looked at the board and it is marked B0483. I bought it as the 1/1.32" 64MP Auto Focus model, but I didn’t realize the OS image was tied to a specific module. So the B0528 image I flashed is meant for the B0339/B0399 one?
Yes, that’s the root cause. B0528 is designed for B0399/B0339, so it cannot drive the B0483 camera you actually have, which is why you get ‘no cameras available’. For the B0483 (OV64A40 native camera), follow the quick start guide here: 64MP OwlSight - Arducam Wiki
To confirm which module is which:
B0483: Arducam 1/1.32" 64MP Auto Focus Camera Module for Raspberry Pi
B0339: Arducam 64MP Autofocus Camera Module for Raspberry Pi
Thanks, I’ve started going through that guide. So I need a different image/dtoverlay than the B0528 one? I was starting to worry I’d been pointed to the wrong image originally.
Right. The key point is that the OS image and dtoverlay must match the actual camera module model. B0528 will not work with the B0483 no matter how many times you reseat the cable or reinstall, because it was built for a different module. Use the OV64A40 quick start guide from a clean flash and apply the settings it specifies for the B0483.
Just updating to confirm: I reflashed using the image/dtoverlay settings from the OV64A40 quick start guide and libcamera-hello now detects the camera. It’s working now. Thanks for pointing out the B0483 vs B0339 mismatch.
