Arducam 64MP - again.... Error -5 / Chip id does not match
Alllllright, here`s my journey getting 64MP Camera running. (spoiler: did not work yet)
HW Setup: I have two RPI5 and two 64MP Quad-Boards with Cameras.
I have also a single, not Multiplex, 64MP Hawkeye.
After messing around with the Multiplexer, reading tons of forums and trying things I am trying a structured step-by-step aproach now. So, starting with the RPI5, the 64MP Hawkeye (single) on cam1 and a fresh installation:
Installed fresh RaspiOS via rpi-imager:
  • bookworm lite
  • Release date: March 15th 2024
  • System: 64-bit
  • Kernel version: 6.6
  • Debian version: 12 (bookworm)
Checked /boot/overlays/ folder, arducam-64mp.dtbo is already contained.
Added /boot/firmware/config.txt
dtoverlay=arducam-64mp
the camera_autodetect is still 1 and everything else is unchanged.
Restarting with camera attached.
dmesg | grep ardu
[ 4.900340] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[ 4.959288] arducam_64mp 4-001a: chip id mismatch: 4136!=7388
[ 4.987769] arducam_64mp: probe of 4-001a failed with error -5
Here we are again, same situation as in all other installations the last days. My understanding:
  • Cam is attached and recognized
  • the driver seems not to accedd the cam due to a mismatch in some „chip id“.
next step:
Set autodetect to 0 in config.txt
→ no change
added cma=512 to config.txt & reboot
→ no change, still chip id mismatch
Physical shut down to see, if hot reboot and cold start change anything regarding firmware…
→ no change
So, possibel branch of actions:
  • I could install the libcam and apps → did not work last time and does not seem to be the issue here
  • I could update rpi os via apt-get update / upgrade → did not work last time and changed to a kernel that was not recognized by the arducam script, so I ruled that out for now (current kernel is 6.6.20+rpt-rpi-2712)
  • I could try to install new driver… decided to do this step:
wget & changemod +x, then
sudo ./install_pivariety_pkgs.sh -p 64mp_pi_hawk_eye_kernel_driver
Got output:
is kernel driver
Release/
Release/arducam_camera_selector.sh
Release/uninstall_driver.sh
Release/install_driver.sh
Release/bin/
Release/bin/6.6.20-v8-16k/
Release/bin/6.6.20-v8-16k/arducam_64mp.ko.xz
Release/bin/6.6.20-v7/
Release/bin/6.6.20-v7/arducam_64mp.ko.xz
Release/bin/6.6.20/
Release/bin/6.6.20/arducam_64mp.ko.xz
Release/bin/6.6.20-v7l/
Release/bin/6.6.20-v7l/arducam_64mp.ko.xz
Release/bin/6.6.20-v8/
Release/bin/6.6.20-v8/arducam_64mp.ko.xz
Installing ARDUCAM_64MP…
Restart with cold restart (power off)
And here we are - still in the loop:
[ 4.715512] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[ 4.716532] arducam_64mp 4-001a: chip id mismatch: 4136!=7388
[ 4.778004] arducam_64mp: probe of 4-001a failed with error -5
now, just out of ideas, I completed the installation
sudo ./install_pivariety_pkgs.sh -p libcamera_dev
Still where I have been before:
[ 4.951712] arducam_64mp 4-001a: chip id mismatch: 4136!=7388
[ 4.965115] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[ 4.994466] arducam_64mp: probe of 4-001a failed with error -5
So, I am running out of ideas. It seems there is an issue with the delivered Hawkeye Hardware vs. the Drivers.
I saw similar topics on the forums around, sometimes it seems to have worked after a while, which I do not understand, as the cam seems to be detected, a chip id can be read and it seems not to match the driver setup of Arducam?
Any more Ideas???
Took me 5 days, here we are: I am dump.
So, in case you ran into the same issue:
The PI5 has a small size connector. So you need a different cable.
BUT: There are two one-to-one versions!
one-to-one SAME side and one-to-one Mirror.
And while it look same, the mirror without twisting the cable TURNS AROUND the pins… and that is what you need!
So, as soon as I used the mirror cable it worked!
I spend 5 days to find that out, hopefully it helps someone out there…
Hi @camman
The cable which is one-to-one SAME side is not for the Pi 5 and 64MP camera modules.
A new native word learned :cowboy_hat_face: It is one of the frequent problems that many customers might use the cable with the same side to connect his/her Pi 5/zero. I did not have the drill to express the concept of “mirror cable”. I told them they should not use the peer cable. Sometimes they would be confused about what I was saying.
Anyway, thank you for your time and feedback :slight_smile:
just tell them that the “metal on in the port has to touch the metal side on the cable” otherwise there is open circuit
Hi Henri,
Cool. Got it :smiley:
