Hi all, hoping someone here can point me in the right direction. I’ve got a Raspberry Pi 5 running Raspberry Pi OS Bookworm, an Arducam Cam HAT (UC-512 Rev D2) and the 4x Arducam IMX519 16MP Autofocus Synchronised Quad-Camera Kit. I just can’t get the four cameras working. Running libcamera-hello --list-cameras only shows one camera, and when I try a preview it throws an error and never shows the camera view:
[0:09:43.101730608] [2865] ERROR RPI pipeline_base.cpp:1337 Camera frontend has timed out!
[0:09:43.101756590] [2865] ERROR RPI pipeline_base.cpp:1338 Please check that your camera sensor connector is attached securely.
[0:09:43.101769034] [2865] ERROR RPI pipeline_base.cpp:1339 Alternatively, try another cable and/or sensor.
One more thing — one of the cable connectors looked damaged when it arrived, so I’ve kept that cable separate from the others.
Thanks for the write-up. A couple of quick checks first so we’re on the same page. Can you confirm the exact revision printed on the HAT (I’d expect UC-512 Rev D2) and the LED behaviour? Normally the red 3V3 LED stays on and the other LED blinks green at startup. And could you paste the output of libcamera-hello --list-cameras so we can see exactly what libcamera detects?
Sure. The HAT is marked UC-512 Rev D2. The red LED is always on, and the other one blinks green when the Pi boots. For list-cameras, it really only lists a single IMX519 camera — none of the other three show up, even though they’re all connected to the HAT.
Okay, that matches what I’d expect for a HAT that’s powered and enumerated but only seeing one sensor. Before we go further — have you changed /boot/firmware/config.txt for the IMX519, and if so, what did you add? Also, do you have another camera you can plug directly into the same Pi 5 to rule out the Pi and OS side of things?
I followed the Arducam website instructions for the IMX519 and added the settings to config.txt, but it didn’t make any difference. I also tried a new Pi Camera 2 connected directly to the same Pi 5, and that works fine. So the Pi and OS seem okay — the problem looks specific to the Arducam HAT, the IMX519 cameras, or the cables.
Thanks, that’s a big clue. Since a Pi Camera 2 works on the same Pi 5, the Pi/OS/libcamera side is basically ruled out. The ‘Camera frontend has timed out’ error, only one of four cameras being detected, and that damaged cable connector all point more toward a hardware/connection problem than a config.txt issue.
To dig further, could you send us pictures of the hardware connections — both the Raspberry Pi end and the camera end — via private message? And please generate a bug report:
Done. I rebooted, downloaded the tool, made it executable and ran it — it produced arducam-bug-report.txt in the current directory. I’ve sent the file and the photos of both ends of the connections through private message. What should I look out for next?
Thanks for the report and the photos. We haven’t pinned down the root cause yet. Right now the main suspects are an insecure camera sensor connector, a faulty or damaged cable or sensor, or a HAT hardware issue — especially given the libcamera timeout, the single-camera detection, and the damaged cable you kept aside.
For now, the conclusion is to keep that damaged cable out of the setup and double-check every connector is fully seated. We’ll review the bug report and the photos and get back to you with the next step.
