Arducam 2.3MP AR0234 camera USB timeout error on Orin Nano USB shield
Hi everyone. I’m stuck with an Arducam 2.3MP AR0234 camera. When I open the Windows GUI and try to get a preview, it just keeps showing “USB timeout Error”. Has anyone run into this before?
Welcome. That error usually means the host isn’t talking to the camera properly. Can you give me the exact hardware and OS setup? Which camera module, which USB board, and which guide you followed?
Sure. The camera is the Arducam 2.3MP AR0234 for Orin Nano, model B0429. I’m using the UC-980 rev.b USB shield, connected to a PC over USB. I’ve tried Linux and Windows 11. I followed the Windows GUI quick start guide from the USB Industrial Camera docs. I also pulled the AR0234 driver from Arducam’s GitHub and it lists this sensor as supported, so I assumed it should just work.
Thanks. When it fails, do you have any more detail than the GUI message? Can you paste the exact error or log output you see?
The only feedback the GUI gives is “USB timeout Error”. I’ve tried the GUI and also Python on both Linux and Windows 11. I even tried wiring the camera directly to a Jetson Orin Nano devkit with the MIPI cable. Nothing has worked - I’ve never been able to get a frame out of it, so I can’t tell if the module itself is dead. Two things I’m confused about: does a MIPI camera used with a USB shield need extra setup? And is there a way to verify whether the camera module actually works?
Thanks for the details. The core issue is your USB config: combining the B0429 camera module with the UC-980 rev.b USB shield isn’t a recommended or supported standalone setup. The B0429 is designed to be used directly on the Nvidia Jetson Orin Nano Dev Kit. That explains the USB timeout you’re seeing.
That makes sense, I was starting to think the shield combo was the problem. So what’s the supported way to use this over USB? And the B0429 on its own with the Orin Nano - that should work, right?
Right. For USB, don’t pair the camera module and USB shield separately - use the Arducam 2.3MP AR0234 Color Global Shutter Camera USB 2.0 Evaluation Kit instead. It’s listed here: Arducam 2.3MP AR0234 Color Global Shutter Camera USB2.0 Evaluation Kit. And yes, the B0429 can be used directly on the official Nvidia Jetson Orin Nano Dev Kit.
Okay, I’ll look at the eval kit. For the Jetson route, what do I need to check? Is there a specific driver or JetPack version?
A few things. The B0429 can NOT work with a third-party carrier board, so make sure it’s the official Orin Nano Dev Kit. Check your JetPack version against the supported list. The JetVariety driver is what drives the B0429 module. So: verify JetPack is supported, install the JetVariety driver for B0429, then follow this guide: Quick Start Guide - Arducam Wiki
To wrap up: your USB timeout is because B0429 + UC-980 rev.b isn’t a supported combination. For USB use the AR0234 USB 2.0 evaluation kit. For Jetson, run the B0429 directly on the official Orin Nano Dev Kit with a supported JetPack version and the JetVariety driver. That’s the current conclusion.
