online from uctronics.com -
Arducam 1MP (OV9782 Color) Quad-Camera Bundle Kit -
Nano B02, jetpack L4t.32.5.1, Ubuntu 18.04 -
Camarray – Arducam 1MP (OV9782 Color) Quad-Camera Bundle Kit - Arducam -
python3 arducam_displayer.py -f RGGB --width 5120 --height 800 -d 0 --fps
core dump , illegal instructions. -
dmesg |grep arducam
reading register 0x103 failed
probe failed
failed to setup board
firmware version 3
sensor ID : 0x0000
sensor arducam-csi2 8-000c registered
subdev arducam-csi2 8-000c bound -
upgrade linux kernel to latest 4.9.230 by upgrade jetpack to latest.
plug and ubplug cable, check power support for board, reboot -
video not showing up. suggestions how to get the video showing.
Hi @bobding
Can you execute v4l2-ctl --list-formats-ext and send the result to me?
You can also use the following methods to test the camera:
- Try to use vlc to access the camera.
- Use this command to test the camera:
v4l2-ctl --set-fmt-video=width=5120,height=800 --stream-mmap --stream-count=-1
Here are results
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘GREY’
Name : 8-bit Greyscale
Index : 1
Pixel Format: 'Y10 '
Name : 10-bit Greyscale
Index : 2
Pixel Format: 'Y16 '
Name : 16-bit Greyscale
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 44.55 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 44.50 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 44.51 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 44.42 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 44.44 fps
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 44.41 fps
VLC play followed this doc exactly but VLC not show anything
Thank you for the information,
It looks like everything is normal with the camera.
Maybe not to set the resolution and format information?
Can you try not to add the -f parameter? From the above information, the camera is working normally. Perhaps this is an application problem.
