Where did you get the camera module(s)?
Kickstarter -
Model number of the product(s)?
N/A -
What hardware/platform were you working on?
Raspberry Pi Zero 2 W -
Instructions you have followed. (link/manual/etc.)
I followed all instructions regarding the installation of the module. Tests with libcamera-still and libcamera-vid are successful. -
Problems you were having?
I can’t get ffmpeg to record video. I tried using /dev/video0 with v4l2 but had no success. In the most simple form, the record command looks like this:
ffmpeg -f v4l2 -i /dev/video0 test.avi
Result:
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
[video4linux2,v4l2 @ 0x881cd0] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0x881cd0] Time per frame unknown
[video4linux2,v4l2 @ 0x881cd0] ioctl(VIDIOC_STREAMON): Invalid argument
/dev/video0: Invalid argument
In dmesg I get the following entry every time I try to start ffmpeg:
unicam 3f801000.csi: Failed to start media pipeline: -22
- The dmesg log from your hardware?
imx519 10-001a: Device found is imx519
imx519 10-001a: Consider updating driver imx519 to match on endpoints
and in case of an ffmpeg start:
- Troubleshooting attempts you’ve made?
I tried all sorts of additional parameters, other video devices, different configurations in /boot/config.json, but nothing fixed the issue.
I also used v4l2-compliant to check if /dev/video0 should works, the result is good:
Total for unicam device /dev/video0: 46, Succeeded: 46, Failed: 0, Warnings: 0
- What help do you need?
I’m using a third party software that supports ffmpeg video streams as an input. So I need to get the camera running with ffmpeg. All my tests via v4l2 where unsuccessful so far.
Best regards
1024kilobyte
