UCTRONICS
B0290
Jetson Xavier NX
Yes
I try to set a fixed focus and exposure time to my camera (16MP, USB-UVC, Autofocus).
The problem is when I run the script the first time, the image is OK. But if I run it again (and again), I get a blurry image. The only way to get back a good image with the correct focus is to change a little the focus value (for example 350->351) before running again the script.
How can I avoid that?
What am I doing wrong?
Here the script:
import numpy as np
import cv2
import time
import os
from datetime import datetime
cap = cv2.VideoCapture(0, cv2.CAP_V4L2)
Set MJPG Mode
fourcc = cv2.VideoWriter.fourcc(*“MJPG”)
cap.set(cv2.CAP_PROP_FOURCC, fourcc)
Set resolution
cap.set(cv2.CAP_PROP_FRAME_WIDTH, 3264)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 2448)
Set exposure time
#cap.set(cv2.CAP_PROP_AUTO_EXPOSURE, 1)
cap.set(cv2.CAP_PROP_EXPOSURE, 30)
Set focus
#cap.set(cv2.CAP_PROP_AUTOFOCUS, 0)
cap.set(cv2.CAP_PROP_FOCUS, 350) # need to change before each run of the script
time.sleep(1)
Capture frame
ret, frame = cap.read()
filename = datetime.now().strftime("%Y_%m_%d-%I_%M_%S_%p")
cv2.imwrite(filename+’.jpg’, frame)
cap.release()
Thanks in advance!
Daniel
