Arducam 12MP IMX708 USB 3.0 camera only shows 1500x1000@10fps, cannot change resolution on Ubuntu 22.04
Hi, I’m having trouble with my Arducam 12MP IMX708 Motorized Focus USB 3.0 camera module (#B0474C). I’ve been following the setup guide on your site (v4l testbench etc.) but I can’t switch the resolution. When I query the camera directly it only reports something around 1500x1000 supported, and only at 10 fps. I also tried it under Windows to rule out my Ubuntu 22.04 setup and couldn’t get it to run at all there. Windows isn’t my target OS, but I wanted to check anyway. Any idea why the higher modes aren’t showing up?
Thanks for the details. Before we go further, can you confirm the camera is plugged into a USB 3.0 port on the PC? This camera needs a proper USB 3.0 connection to expose its full mode list. If it’s on a USB 2.0 port or going through a hub, that could explain the missing resolutions.
Yes, it’s connected to a USB 3.0 port using the cable that came from Arducam. Other USB 3.0 cameras work fine on these machines, so the ports themselves seem OK. Just to recap what I’ve tried: followed the website setup guide, queried the camera directly for supported resolutions (only ~1500x1000 @ 10fps showed up), and tested under Windows as a sanity check. Target OS is Ubuntu 22.04, Windows was just to rule out an OS install issue. Nothing changed.
Got it. Since the port and cable look fine but the full modes are still missing, I’d like to take a closer look at the device state. I’ve sent you the remote support details privately - please check your messages. I’ve also sent a scheduling link so we can pick a time that works. Note we’re on UTC+8 (Beijing/Hong Kong time zone); the 22:00 slot on the calendar is only for sales and won’t work for remote support.
Small update while I was getting things ready for the remote session - I reconnected the camera on the exact same ports as before and now it’s showing all the required modes. It seems like previously it wasn’t registering as a USB 3 device at all, which is why the modes were missing. What’s strange is this showed up on multiple independent machines. Anyway, right now it presents everything and works as expected.
That matches what the manual describes. When this camera falls back to USB 2, the video modes go missing - that’s exactly the ~1500x1000 @ 10fps behavior you saw. So the root cause was the camera not registering as a USB 3.0 device and falling back to USB 2. Once it registered properly as USB 3.0, all the required modes came back. I don’t have a solid explanation for why it happened across multiple machines, but the fix is to make sure it’s actually detected as a USB 3.0 device and not in USB 2 fallback. If it drops back again, replugging and rechecking the connection would be the first thing to try.
