Arducam 108MP USB3.0 Dev Kit USB TIMEOUT ERROR
    I got the camera module from the Arducam website
    https://www.arducam.com/product/108mp-usb-3-camera-evaluation-kit/
    SKU: EK030
    I’m working on the Raspberry Pi 5 running the latest OS Bookworm.
    I’m running all the code in the Thonny IDE
    I downloaded the required USB drivers off of github by running the udev_configure_rules script
    I installed the two libraries ArducamSDK and arducam_config_parser
    GitHub - ArduCAM/ArduCAM_USB_Camera_Shield_Python_Demo
    I downloaded the arducam_demo python script, and modified the code to simply define an arducam camera object. I gave the openCamera function the cfg file. Then I say camera.start().
    It would print: Capture Began, Error: USB_CAMERA_NO_ERROR
    Which means the camera has successfully started up.
    The problem appears when trying to initiate an camera.read() function
  5. Problems you were having?
    When I use the camera.read() function, a USB timeout error appears
    It would print: Error capture image : USB_CAMERA_USB_TIMEOUT_ERROR
  6. Troubleshooting attempts you’ve made?
    I tried this camera on a windows 11 pc with the GUI. I downloaded the drivers, and cfg files.
    The GUI recognizes the camera, and also loads the cfg file successfully.
    The second i press Play, it has a USB TIMEOUT ERROR
    It seems to have the same issue on both windows and raspberry pi
  7. What help do you need?
    What can be done to rectify this error? Is there something I’m missing?
